Car won't start. Is it the starter?
Old May 18, 2008 | 01:23 PM
devilz05's Avatar
Shift_3.0
The last 3 times I turned on my car it would barely start. On the 4th time, all I heard was quick clicking and the lights on the dash would flash. After a few more attempts it doesn't even appear that its clicking anymore. This may be completely unrelated but the problems started after I filled up my tank with Sunoco gas. The tank was on empty so when I filled it up and started having the issues I began to think that perhaps they sold me water with gas flavor. When I the key, my radio turns on and I am able to open and close the windows. That led me to think that the battery is ok. The battery is pretty old so is it possible that it has enough juice to run the radio but not start the car? Any help would be appreciated to what the culprit might be.
Thanks in advance!
Edit: After further investigating, it appears that my radio dies shortly after turning on. This leads me to believe that it is in fact the battery. Thoughts?
Old May 18, 2008 | 01:58 PM
pmohr's Avatar
No more Maximas...
If you're getting slow startups, clicking, then nothing...most likely your battery.
Have you checked voltage across the terminals?
Old May 18, 2008 | 02:27 PM
Turbobink's Avatar
check the battery first...
Old May 18, 2008 | 02:44 PM
devilz05's Avatar
Shift_3.0
I'm thinking it's the battery as well. First chance I get, I'll replace it.
Old May 18, 2008 | 04:50 PM
fat_kid's Avatar
try to jump it first
Old May 18, 2008 | 05:08 PM
B_Eaze's Avatar
Jump it. If it works leave it running and drive yourself to sears or something a get a battery
Old May 18, 2008 | 05:36 PM
fat_kid's Avatar
or a new alternator....
Old May 18, 2008 | 05:57 PM
Harbog's Avatar
My car started two or three time then died right out. Now the battery just cranks.
any suggestions? It seems like it is not getting any gas.
Old May 18, 2008 | 06:01 PM
B_Eaze's Avatar
How long did you let it run when it started?
Old May 18, 2008 | 06:12 PM
Harbog's Avatar
It only ran for a few seconds and died right out. No it will not run at all.
Old May 18, 2008 | 06:50 PM
B_Eaze's Avatar
sounds like your not getting gas to ur engine (do u have gas?..) check your fuel pump fuse, might be blown. its right above the hood handle inside the car. Did you try to give it gas once it starts? Might be MAF, is your check engine light on? check you ECU anyways
it could also be a short in your wiring somewhere. Do a search next time and you'll find these
http://forums.maxima.org/showthread....ng+after+start
Old May 18, 2008 | 07:02 PM
ayc123's Avatar
check the fuel pump
maybe the fuel pump itself...
Lakersallday24
Jun 16, 2019 01:35 AM
Btheman80
May 1, 2018 04:03 PM
homewrecker
Aug 24, 2015 08:56 PM
BobMax
Aug 15, 2015 12:35 PM
Samedi
Aug 13, 2015 04:05 PM
