Rear doors....stiff opening and closing.....
Old Nov 3, 2000 | 06:32 PM
Mad Jap's Avatar
Does anyone else have this problem?
I lubed the hinges and the "plunger thingy", but it's still quite stiff.
Anyone know of a fix?
Old Nov 3, 2000 | 06:39 PM
Mike Cline's Avatar
Same problem here. I tried WD-40 but it didn't help. I rarely open my rear doors any way. I think they are just stiff.
Old Nov 3, 2000 | 07:37 PM
MarkP's Avatar
Try using regular wheel bearing....
grease. My left rear door became stiff to open/close and a light smearing of grease on the doors "check link assembly"
as Nissan calls it in the FSM did the trick after a few cycles of opening and shutting. WD-40 is great on some things but not on high pressure friction applications like the check link gismo. Use light oil on the hinges. I use motor oil, very little is needed.
Old Nov 3, 2000 | 07:58 PM
96BLUMAX's Avatar
My doors did that too and then I finally had to replace them because they went bad. I think it is a design fault.
Old Nov 3, 2000 | 08:09 PM
Vitaly O.'s Avatar
same problem here
I tried using some type of grese it worked a little bit but its still tight I just said f it I dont sit in the back anyway
Old Nov 3, 2000 | 08:11 PM
Max Speed's Avatar
I have the same problem with my doors, I thought maybe it was because I never open them.
Also, the child lock on the rear passenger side door always turns itself on. If someone actually gets in the back seat, then they cant get out
Old Nov 3, 2000 | 08:21 PM
tm96max's Avatar
Same problem, tried many different lubes, still are hard to open and close. We don't use those doors much anyway.
Old Nov 3, 2000 | 08:51 PM
maximaisokay's Avatar
MarkP
Were you tring to race with F4 plane? Or you just wanna be cool? What a moron!
John
Old Nov 4, 2000 | 12:11 AM
brandonj's Avatar
I had a problem with one of mine, and I figured out it was that the "track" (the part that slides in and out) wasn't screwed on tight. This was after trying all kinds of lubes - don't I feel dumb. I screwed it down and now the door moves much easier.
Old Nov 4, 2000 | 04:06 AM
Micah95GLE's Avatar
Re: MarkP
John
That's an A4, not an F4. Obviously, the pic is a joke (I remember when he photoshopped it).
Old Nov 4, 2000 | 04:18 AM
96BLUMAX's Avatar
For my car it was the hinges going bad. I replaced both of them after a while and now the doors are perfectly fine.
Old Nov 4, 2000 | 05:35 AM
justmax's Avatar
re: MarkP
Actually it's an A7 Corsair, not an A4 nor an F4. a) the is *ABSOLUTELY* no contest in a race of this nature. b) Jets *NEVER* fly that low. c) finally, that is obviously a photoshop job.
Justin
Old Nov 4, 2000 | 05:43 AM
MarkP's Avatar
Re: Re: MarkP
John
Thanks for straightening the record Micah95gle. Obviously
I mean it to be a roadkill joke. But apparently not obviously enough for someone like maximaisokayjohn!
Old Nov 4, 2000 | 05:51 AM
MarkP's Avatar
A7E Corsair II n/m
Justin
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
cruce91
Sep 20, 2015 10:23 AM
doctorpullit
Sep 10, 2015 06:33 PM
