Rear doors....stiff opening and closing.....
Originally posted by Mad Jap
Does anyone else have this problem?
I lubed the hinges and the "plunger thingy", but it's still quite stiff.
Anyone know of a fix?
Try using regular wheel bearing....
grease. My left rear door became stiff to open/close and a light smearing of grease on the doors "check link assembly"
as Nissan calls it in the FSM did the trick after a few cycles of opening and shutting. WD-40 is great on some things but not on high pressure friction applications like the check link gismo. Use light oil on the hinges. I use motor oil, very little is needed.
I have the same problem with my doors, I thought maybe it was because I never open them.
Also, the child lock on the rear passenger side door always turns itself on. If someone actually gets in the back seat, then they cant get out
I had a problem with one of mine, and I figured out it was that the "track" (the part that slides in and out) wasn't screwed on tight. This was after trying all kinds of lubes - don't I feel dumb. I screwed it down and now the door moves much easier.
Re: MarkP
Originally posted by maximaisokay
Were you tring to race with F4 plane? Or you just wanna be cool? What a moron!
John
John
That's an A4, not an F4. Obviously, the pic is a joke (I remember when he photoshopped it).
Re: Re: MarkP
John
John
I mean it to be a roadkill joke. But apparently not obviously enough for someone like maximaisokayjohn!
A7E Corsair II n/m
Originally posted by justmax
Actually it's an A7 Corsair, not an A4 nor an F4. a) the is *ABSOLUTELY* no contest in a race of this nature. b) Jets *NEVER* fly that low. c) finally, that is obviously a photoshop job.
Justin
Justin
doctorpullit
09-10-2015 06:33 PM
