Ask a Idiot who just stripped his Knock Sensor threads by over tightning Anything!
Im so pissed off. I was about to replace it and Soon as I put the new one in i started torquing it, which didnt even seem like much force, but it snapped and now the bolt just spins freely not locking in.
What now?
What now?
anyone tried this?
99black, wont i have to use a larger size tap since the hole doesnt have anymore meat? Wont that prevent the new bolt from fitting the knock sensor hole?
http://cgi.ebay.com/NEW-10-MM-X-1-50...QQcmdZViewItem
Found these. Are the thread pitch for KS 12mm bolts x1.50 or x1.25?
Found these. Are the thread pitch for KS bolts 1.50 or 1.25?
The knock sensor is just a failsafe mechanism to keep you from damaging your valves if something is wrong with your engine and causes it to ping. If your injectors are clean and you run the proper octane gas and you keep your engine tuned up and clean then you will never have a knock during normal conditions--under any type of load.
I've been running mine on my intake for more than 35k miles with ZERO trouble.
Here is a picture of where mine are located on both my Max and I30:
ill give it a try. thanks
If it were me, I wouldn't relocate the KS to the IM. I would look at another place either in the valley, or on the block somewhere. The IM might cause the KS to loose some of it's effectiveness it might not be able to sense less intense detonation. Of course that's me.
S
S
S
S
The knock sensor will actually pull ignition timing out when it senses detonation - something it can't do as effectively if it is located all the way up on the IM IMHO. There are numerous gaskets and whatnot the sound/vibration has to through in order to get to the KS that way. Leave it in the valley and do it right...
And you are going to hurt your aluminum pistons before you hurt the steel valves with detonation; it's a good way to break a piston if it gets bad enough. Granted, you shouldn't be getting detonation if you are using premium gas, but if it is hot enough outside and the engine gets loaded down in the right, you CAN get it.
-Matt
BTW, you don't have to mount it where I did. You can mount it anywhere that you can get it grounded. The only reason I even use a knock sensor is because I might sell the car someday and have to put it back where it belongs. In fact, I've used resistors in place of the KS to fake out the ECM.
I'd like to see a picture of that. I have never seen a 4th gen engine that didn't look exactly like the one in the picture--and I've been under the hood of a lot of 'em.
S
Man, if you were boosted like I am, you'd rethink putting resistors in to mimic a KS. Even N/A, depending on what mods you do, I really think it's a bad idea to do that. Maybe for light mods it'd be okay...but I wouldn't ever recommend it to anyone. If you don't get the resistors right, the ECU can pull quite a bit of timing, and can make a HUGE difference in performance, and at times, you won't get a CEL neccessarily.
S
S
Second, there is a HUGE misconception of how the KS works on a 4th gen. It has NOTHING to do with timing unless there is a knock detected. Then it sends a signal to the ECM which retards the timing. During normal operating conditions (meaning non-ping conditions) the timing is preprogrammed in the ECM and is varied based on what the ECM has been programmed to do with changes in input from the TPS, cam and cranksensors, MAF, etc.
I'm just telling you what I've experienced and what I've read in the Nissan FSM.
I know what you're thinking. I've also read those detailed posts showing different specs with and without the KS. The problem is that those comparisons were done using a KS installed then NO KS. When the ECM sees NO KS it operates in failsafe mode and uses retarded timing parameters programmed for failsafe. When the KS is put back on it switches to standard parameters.
IF you would do the same comparison with a 600 ohm resistor in place of the KS you would find the EXACT same timing as with the KS. The ECM only knows whether the KS is attached and working based on voltage drop on that circuit. Once it knows the KS is attached it doesn't care about the KS unless the voltage changes on that circuit--like when the KS detects pinging.
If there is some documentation or proof you can provide me that tells otherwise I would love to read it.
S
Its a 12mm Bolt for the record incase you havent been answered that yet,
my question to you my friend is... did you remove the UIM as directed by any instruction on the face of the planet or were you being a rebel and attempting the bloody fingers method?
I know its a 12mm, but whats the Pitch? 1.25? x.150? x 1.00?
There's no way I'd spend all that time taking the UIM off to do a 5 minute job otherwise...
-Matt
I have run my car with the KS bolted to the upper intake for 6 years while boosed. Takes 5 min. If you look at the picture it is bolted at the base of the upper intake manifold, where it meets the lower manifold, right next to the front injectors.
u buy a longer bolt? Wut size?
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
