Running speaker wire into the door
Old Jun 10, 2008 | 11:48 AM
KhanMan13AK's Avatar
For those who have done this, is it a tough process? In my 350 I had to dremel out brackets that went into the door and it ended up being a pain in the @$$!! Do you just push the wire through or is there something more involved?
TIA, Im replacing the speakers and adding a four channel amp. Amp is in the trunk so I will directly connect to the rear components. I am also installing components in the front and want to have the crossover in the kick panel. Idealy, I want to run the wire from the amp directly to the crossover and not have to mess with any of the stock wireing.
Old Jun 10, 2008 | 12:05 PM
BLACKonBLACK98's Avatar
Former Vendor
doesn't sound like you really have a choice... you'll figure it out.
Old Jun 10, 2008 | 12:12 PM
What an insightful response... thanks for your help!
I know I'll figure it out... just curious what I am in for and if its worth it. I can also throw em in the door and use the ****ty stock wires.
Old Jun 10, 2008 | 12:42 PM
Former Vendor
what an insightful question!
its running wires to doors... i don't really know what you're looking for here. you move some panels and stuff out the way and thread wires through the door loom (i use coat hangers sometimes). better?
Old Jun 10, 2008 | 03:40 PM
maxprivate's Avatar
Black Lion
Sorry had to laugh at his one. I guess what he meant was that once you start doing the actual work most time things will start to flow hence "figure things out". Sometimes things can be taken out of context.
Old Jun 10, 2008 | 04:50 PM
AscendantMax's Avatar
no easy way around it, you will have to fish the lines through somehow. for mine, i took off the rubber boot/grommet thingy on the doors so i can bend it straight....then used a close hanger to fish the line through. it's a PITA but doable.
Old Jun 10, 2008 | 06:52 PM
djfrestyl's Avatar
Suspension Yoda
Helps if you tell us what year your car is.
In a 4th gen you can fish the wire through. It takes work, and, no homo, lube helps (I use vaseline)
In a 5th gen you CANNOT fish the wire through the grommet, because there is a molex plug AT the grommet. You have to drill to get the wire out of the car, I always drill behind the kickpanel.
The above information applies for front doors only. In both generations, you can fish the wire through in the rear doors.
Old Jun 10, 2008 | 07:22 PM
Thanks for the info... I have a 5th gen. and I guess I am in for a similar situation to my 350z. You can basically drill through the chasis or dremel out the molex plug and run the wire through the actual plug.... great
Old Jun 10, 2008 | 07:57 PM
kpr10is's Avatar
Not even that it has been posted that recently, I mainly just felt like getting a free post from this thread.
Old Jun 10, 2008 | 09:11 PM
slickrick's Avatar
I agree.
Old Jun 10, 2008 | 11:18 PM
FlipCpt45's Avatar
there was a small grommet behind the rubber plug piece... i was like wtf are they talking about.. after like 3 hours of figuring out wtf im going to do, my friend comes over and says, hey... whats this little rubber piece behind the plug? :P
Old Jun 11, 2008 | 04:28 AM
djfrestyl's Avatar
Suspension Yoda
Do NOT try to dremel or drill through the molex plug like on the 350Z, there is no space to do so and you will severely screw up your wiring harness. Drill behind your kick panel, make a small slit and fish the wire into the rubber loom and then into the door.
Old Jun 13, 2008 | 12:39 PM
CarAudioHelp's Avatar
If you really don't want to mess with it you should be able to use the existing door speaker wires. Find the speaker wires that connect to the speaker (the easy part) and then find the same wires where the come into the cabin (kick panel area). Clip the wires, insulate the side that goes to the factory amp and tie in your new wires to the ones already going into the door. No, it's not ideal but that small run of wire won't really affect the sound much if at all. I guarantee 99%+ of the people won't really hear a difference and 100% won't hear a difference with the engine on.
Old Jun 13, 2008 | 01:03 PM
Former Vendor
or run a new loom... tons of options here. you'll figure it out.
Matt93SE
May 24, 2019 02:58 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
Abdelrhman
Aug 17, 2015 12:16 PM
MikesChevelle
Aug 9, 2015 11:50 AM
