Passenger Door issue.
The passenger is hard to close. I should push the door three time harder than the other doors. I checked hinges and connection parts. There is no rust and greese. I can't remember when the problem has occured. I think the car had an accident before I bought even though Carfax was clear. How can I fix the issue.
Thanks.
Thanks.
open the door and take off the middle "hinge". its held on by one 10mm bolt. see if that makes any difference. if not grab a 12mm, with the door open loosen the 2 bottom bolts on the body in between the doors and loosen the two top bolts on the door. do not take them out only loosen them less than halfway. close the door gently and tighten them up. that should do it if not bring it to a body shop.
if the hinge sags say 1/8 of an inch ,at the other end of the door (aprox 2feet away) that turns in to say 1/4 or 3/8 of an inch at the striker.
Im just throwing numbers out to demonstrate why it would make a differnce, I am not saying those numbers are what it is.
hope this helps
Here is question. I have a 96 I30. The most of engine parts are pecfectly fit to my car.
I'm willing to buy the check link assembly by used maxima part but I don't know whether does it fit or not? Anyone?
Thanks.
Thanks.
HerpDerp1919
Sep 29, 2015 02:02 PM
