Has it happened to you before?
Old Jun 22, 2008 | 03:05 PM
GReDdyXMaXiMa
Okay heres the deal, when I bought the car someone cut the spring down with all stock shocks & springs & of course it bounce alot like basketball but damn i cant wait my new package come in this week to change springs * shocks.
The engine runs funny last night and i was like it must be misfire so then finally I decided to check it out today and took one spark plugs out which it was already loosen and the oil is all over on number 5 cylinder.
Any suggestion , I thought about starting up not start to take the oil out of cylinder 5 for me to be able to put new spark plug in.
Obviously you know ghetto rigged shocks & springs cause alot of virbation and make the plugs screw loosen.
any help will be helpfully thanks.
Old Jun 22, 2008 | 03:55 PM
pmohr's Avatar
No more Maximas...
And this is on your third gen?
Old Jun 22, 2008 | 04:53 PM
GReDdyXMaXiMa
No , it is an 98 inifniti I-30
My pictures on sig is OLD so i gotta remove it soon.
Old Jun 22, 2008 | 07:35 PM
Godson's Avatar
Im kinda confused though bro.....whas the connection with the bouncy ride and oil on your plug? The plug being loose,IMO, would not have anything to do with even worst suspension,just dont think bouncy ride is gonna loosen a plug. The oil on the plugs is its own,unrelated issue.
Old Jun 22, 2008 | 08:06 PM
arrocha87's Avatar
uhm isnt oil in the plug the valve cover gasket? and more specifically the spark plug grommets that come in the kit when u buy a new gasket kit?
Old Jun 23, 2008 | 11:08 AM
I've got a suggestion for you.
http://forums.maxima.org/showthread.php?t=547220
Old Jun 23, 2008 | 11:20 AM
GReDdyXMaXiMa
Yes, The bounce has caused my spark plugs to loosen up and the oil went thru cylinder # 5. I had to take the oil out by starting not start the engine , just lil bit of crank to take the oil out , finally it came out real messy then cleaned with rag & use the compression air blower to blow the oil out then put the spark plugs back in ...bam it works better now.
Where I live in Boston , it has MANY MANY bad roads bumpy and potholes. If you drive a car with basketball suspension and the oil will go bad.
Im getting new suspension kit for my car and will arrive at the door on friday. I'll have picture post after its done.
Old Jun 23, 2008 | 11:22 AM
GReDdyXMaXiMa
ya , I think you are cool. thanks for sharing with me.
Old Jun 23, 2008 | 11:27 AM
ajcool2's Avatar
Um get a new valve cover gasket.
Old Jun 23, 2008 | 01:38 PM
maximase86's Avatar
I love lamp.
Ummm that's not a good thing if your plugs come loose on bumps. You sure that the leaky spark plug grommet didn't simply foul up the connection between the coil and the plug?
S
Old Jun 23, 2008 | 02:15 PM
bmessick's Avatar
I'm glad the car is running better for you now that you have blown the oil out. Not only is it running better but will ride much better when you get the proper suspension on the car.
Old Jun 23, 2008 | 04:16 PM
Godson's Avatar
S
Yea thats what Im sayin. Cant see how bouncing could manage to rotate a plug what,6-8 turns the lenght of the plug thread? im not saying it wasnt loose,but probably poor installation or something. Either way,good move on getting rid of the cut springs and just square that oil issue away and you should be golden.
Old Jun 23, 2008 | 06:30 PM
QNO_A32's Avatar
"If you drive a car with basketball suspension and the oil will go bad."
i am disgusted.............oops....
Old Jun 23, 2008 | 06:36 PM
mevjen's Avatar
The self-oil changing max
You could drive your car off a cliff, and I guarantee you the spark plugs won't back out of the threads if you torqued them properly... Change your spark plug tube seals. They are rubber grommets that go around the tubes. Often they crack and leak.
Also, oil shouldn't even be around the spark plugs, so even if they were loose, the problem I would expect is poor compression or a stripped thread.
Old Jun 24, 2008 | 08:36 AM
maximase86's Avatar
I love lamp.
****, I think my oil is bad now. Damn Seattle potholes.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
