car keeps stalling!!!!
Old Aug 13, 2008 | 08:13 PM
bcmaxima96's Avatar
sup guys, so i have a 96 max and as of recently its been stalling alot on me and having an irregular idol. sometimes the car will run fine, but other times it'll start out running fine then when i let off the gas it either stalls , or the rpm's drop very low and i have to rev the engine to keep it running. also sometimes while i have my foot on the gas i feel it hessitate and the engine will sputer. So if anyone has any idea of things i can do to try and diagnose my problem i would apreciate it..
thankssss
Old Aug 13, 2008 | 10:03 PM
xmfan's Avatar
Maybe is the MAF
Old Aug 13, 2008 | 10:49 PM
ZeoGox's Avatar
hey men, i have the same problem, i hope someone could help us, haha
Old Aug 14, 2008 | 06:15 AM
bcmaxima96's Avatar
just wanted to add that the car is also back firing from time to time. I've already changed the fuel filter, thought i just wasn't getting fuel but that wasn;t the quik fix.
Old Aug 14, 2008 | 10:42 AM
j2b4osan's Avatar
I recently had a problem with erregular idle and stalling . I managed to narrow it down to the engine harness where it bends down to head through the firewall near the pas side strut tower. There was a tsb about it. Let the car idle and go under the hood and pull push and wiggle the harness where I described it if there is a bad connection the idle will change every time you move it a certain way. It may even stall. This might not be your problem but it's easy to check. Good luck
Old Aug 14, 2008 | 11:43 AM
bcmaxima96's Avatar
messed with the harness didn't do anything, i also cheked the ecu for codes and all that came up was the intake air temp sensor , and tyhat cuz of my cai. so i'm lost right now!
Old Aug 14, 2008 | 12:14 PM
Krypto's Avatar
Issue sounds to be either the MAF or the injectors, have you checked to see if all of your injectors are firing?
Kruso
Old Aug 14, 2008 | 01:54 PM
Genya718's Avatar
Listen Man I had the same problem! Take off the (mass airflow sensor) and make everything is intact there clean it out too
Old Aug 14, 2008 | 06:35 PM
VenoMax647's Avatar
I had the same problem it turns out one of my injectors was cracked
Old Aug 14, 2008 | 08:43 PM
bcmaxima96's Avatar
yea i was thinking either the maf or the injectors, i checked the injectors by unhooking each one while the car was running and it appears they were all firing, is there any way to check the maf to see if its working properly???
Old Aug 16, 2008 | 01:36 PM
represent24's Avatar
im having the same problem too, i about to check my MAF and make sure everything is niceand tight! thanks for the info!!!
Old Aug 21, 2008 | 08:41 PM
vaso's Avatar
I had this problem a year ago. Replaced MAF - no more problemo. I've bought several replacements but only two (stock) were working properly. Don't buy "home" made. I see one here:
http://www.usedvictoria.com/classifi...passenger-cars
Old Aug 24, 2008 | 06:34 PM
jheaton's Avatar
Check the MAF , does the car have a knock?
Old Aug 24, 2008 | 06:42 PM
patel_anu's Avatar
man, im having the same problem
have you been able to fix the problem?
Old Aug 31, 2009 | 03:18 PM
jazz212's Avatar
My car has a knock we thought that it might be the tie end rods but after replacing them this is still a slight knock. The car is idleing low its stalled once, what does the knock meaning does that come in to play with the maf.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
