CAI ramair for the track idea
I noticed that if you remove the sidemarker you can see the CAI filter. It may look strange but I figure you can modify a small scoup that fits where the side marker is and ram air right into the filter.
Anyone have an old side marker they don't want. It can even have broken lenses. (any ooglie clears gone bad)
Re: CAI ramair for the track idea
SuDZ
Re: Re: CAI ramair for the track idea
Originally posted by SuDZ
Would the scoop be coming out all the way or just going to where the lens is? I am just curious because if it does not stick out from the inside would it be able to get enough air to be usefull?
SuDZ
SuDZ
Re: Re: Re: Re: CAI ramair for the track idea
Originally posted by Y2KevSE
That would probably help a bit, but not much. You need a wider opening (i.e. fog lamp removal).
Need to go to possible the fog lamp. But then again, you also need SMOOOOOOOTH bends in the pipe, anything harse or tight bends also cuts down on the amount of air that can flow quickly and effienctly through there.
Dixit
tarun900
19
Dec 20, 2021 06:57 PM
