KS, MAF, or something else? I'm stumped.
Lately I have been noticing that when sitting on red lights that my RPMs drop 100-200 rpms and then go back up to the regular idling RPM. It also makes little popping sounds out of the muffler and shakes the car every now and then very softly. This problem stops when car is in motion but in 2nd gears if the pedal is pressed more then half way it begins to jump a few times through 3-4k rpm and other then that runs fine. The other unusual problem is that it doesn't do it constantly but at random times, some days doing it all the time and others running completely normal. Does anyone have any idea on what this may be? I appreciate in advance for all the help.
while your at it , also check the camshaft position sensor , its on your left hand side of the engine if you are looking at it. Mine was bad and my car would drop down to like 400 rpms and then just shut down at the traffic light. Took me like a week to figure it out. Unless you have a SES for your MAF or KS , chances are , they are fine.
before you check into all these suggestions, which i might add are not bad ideas. i would start off simple first. is your cel light even on? have you scanned for codes? have you cleaned your iavc lately? is all your vaccums hooked up right?
As far as codes there are no codes which just makes the troubleshooting more of a pain in the ***. I have a feeling its a coil too since it only misfires in 2nd but i will definently check all the hoses and the cam shaft sensor and everything else listed. I know its not the sparks because they are about 10 month old NGK iridium plugs.
i hate sounding like a donkey but most of the advice given so far would be incorrect. diagnosing a vehicle without proper information ie. OEM service manuals is pointless. you can drive yourself crazy trying to figure out drivability problems on your own. my opinion on your complaint is maybe you should go to a nissan dealer spend the hundred bucks or so and have them tell you the real source of your drivability problem and then if you can, fix it or replace the compenent yourself.
With the car running unplug a coil pack one at a time and reconnect, if there is no change in the rpm, when you unplug one, that's your culprit. You also have to consider the last time you changed your plugs.
That is the reason why he's on here asking questions. Why spend money for something you could fix yourself or diagnose yourself.
Yeah, spending a hundred dollars for a person to tell you whats wrong is kinda out of my budget at this point. Ima broke *** college student so the less money I spend on repair means more i can spend on new stuff for the car. I would rather play around with it and find out whats wrong.
I seem to have the same problem. RPM drops close to 300 and when i try to acccelerate it wont let me sometimes it just dies. It shakes some and then it dies sometimes the car tries to move forward but then dies. I do know that my drive axles are pretty bad. I was wondering if they get that bad would this be a problem or am i way off. I dont know much about coils or cars for that matter. but i did change the spark plugs about 3 months ago NGk's Iridiums gapped at .44 or something like that.
btw this my first post!
if you really want to find the problem yourself n on a budget find your self a digital multimeter and a back probe(2 bux at autozone) and private message me and ill try and teach how to self diagnose.
here's a link to my thread - I'm having the identical problem and a lot of advice has been offered there:
http://forums.maxima.org/4th-generat...4500rpm-2.html
why spend the money? i would say that with the issue hes having fiddling with his cop system could lead to damage to either the cop or his ignition module.
I have same problems. Thought they were related, but after I replaced the cat and y-pipe, the acceleration problem went away. The stop light stuttering remains, but I did notice that the grounding strap from O2 sensor was gone. Gonna replace that and see if it helps.
With regards to dealerships, 4 hours of diagnostics, they just shrugged.
i read somewhere on the net someone had same problem and they cleaned the throttle body and the rpm was kept up..im gonna be cleaning mine in a couple of days. maybe it could help solve your problem before you go off and buy more expensive parts to replace
May be a possibility. - Iridium plugs have less resistance through them than the original Platinum plugs. Therefore they tend to draw more current through the coil. This may cause the coil to overheat and malfunction after a period of time.
Yup, sadly its not my biggest problem as of right now. I just put in a new Master clutch cylinder and slave cylinder a few days ago and my clutch pedal managed to get stuck all the way down on the redlight and i barely got it to the side of the road. Checked everything out and it seemed fine and it started back up but did it again 20 or so minutes later so i've been trying not to press the pedal all the way down on stops and hold it there which seems to be working but I have a feeling my clutch has gone to hell which sucks since it was replaced around 5-6 months ago with an Exedy. Everything seems to go to **** at once and when you're low on funds. heh.
TallTom
57
Oct 14, 2025 05:16 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
