What is this part?
What is this part?
So, when I was installing my intake spacers, my buddy recommended that I take this part off since the hoses wouldn't connect anywhere. So I removed it and drove around without it for a while. Then I saw how it was installed on someone else's and put it back on at the NWP meet. The intake was alot louder with this part removed. It didn't seem to affect driveability of the car when it was removed, though. What is it and what does it too? Can I just take it off again without causing long term damage? I liked how the intake sounded without it.
now, i have the NWP block plate on there in place of the VIAS... so is this canister doing anything now?
but if you have the butterfly removed with the vias block plate then it serves no point..correct.. im interested in this.. does the car drive different with it..or are you hearing those vacume lines making noise?
:edit: you beat me lol
the VIAS was designed the way it is for a reason....
My guess would be that you would loose a little down low but not gain alot up top with the vias still in there.... I think thats why people remove it because so much to be gained up top with more space there but you loose a little in the lower rpms.
This is correct. The canister is used in conjunction with the VIAS butterfly valve. No valve = no need for vacuum. You can remove that and the sensor if you want to clean up your upper IM area.
ok.. thanx... its not bothering anything, and im lazy, so i'll probably just leave it there
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
