Clearance Issues?
Old Oct 25, 2008 | 12:52 PM
timmay5835's Avatar
Clearance Issues?
Hey, I am planning on buying some Work rims soon. The rims are 17x8 +47mm offset. Will I have any trouble running these rims? Any need for spacers? Also, what would you guys recommend for tire size because my max is pretty slammed right now. Any help appreciated
thanks,
tim
Old Oct 25, 2008 | 10:29 PM
Fast1one's Avatar
That offset is pretty high, so you may run into clearence issues on the inside. I doubt it though.
They will be sunken battleship status though. I would go with 15mm spacers for the front and 25-30mm for the rear for them to look clean and solve any possible clearence issues.
As far as tire size, 235/45 sounds about right.
Old Oct 25, 2008 | 11:46 PM
MrDicks95SE's Avatar
Offset Is Everything.
sunken battleships FTL. youll be fine with 235/45's on 8's on that setup.
Old Oct 26, 2008 | 06:28 AM
BLACKonBLACK98's Avatar
Former Vendor
like the fitment crew said; sunken battleships ftl. i wouldn't buy those sizes.
Old Oct 26, 2008 | 10:12 AM
timmay5835's Avatar
could i fix this fitment issue (battleship sunken problem) with some spacers?
Old Oct 26, 2008 | 11:22 AM
Former Vendor
indeed you could but unless its a superb deal i would just buy something with better fitment out of the box.
Old Oct 26, 2008 | 12:35 PM
MorpheusZero's Avatar
fitment croo ftmfw
Old Oct 26, 2008 | 12:38 PM
spacers are expensive and annoying, just do it right from the start.
the only reason i'd get spacers is if the wheels weren't available in close enough fitment (and i really liked them), or just for the rear so i could run identical wheels all around and rotate the tires.
Old Oct 26, 2008 | 12:55 PM
spacers are for wimps. dont waste your time. we've all been there. get the right size wheel.
Old Oct 26, 2008 | 04:05 PM
IHAVEA2KMAXIMA's Avatar
Were you looking on honda forums? +47?! lol
+1 just keep looking for the right size. If you're going with 8" width, you should get at least like +35 offset.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
