6th Gen Eyelids and Maintenance Updates
Old Nov 25, 2008 | 07:29 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Installed Black Eyelids (finally found a set I like!!!)
Changed my K&N air filter and replaced it with an APC low profile racing filter.
Before:
After:
Changed Oil catch can filter and added steel wool (copper) inside the oil catch can which acts as a baffle plate to trap the oil.
Old Nov 25, 2008 | 07:33 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Nice chern... I think those are the same lids i have...
paradox systems?
Old Nov 25, 2008 | 07:38 PM
ILL-Maxima's Avatar
Nice eye lids Chern... How are those installed on there, 2 side tape? Luvin the engine bay man
Old Nov 25, 2008 | 07:54 PM
!PrjctMax!'s Avatar
Looks good, but those filters look like they may let to may contaminants pass through.
Old Nov 25, 2008 | 08:46 PM
bandulu's Avatar
nice man looking good in there... is that turbo covered with some kind of bag or something like that?? sorry if is a dumb quest..
Old Nov 25, 2008 | 09:43 PM
chernmax's Avatar
paradox systems?
Same type but I found them just using Google...
Old Nov 25, 2008 | 09:44 PM
IHAVEA2KMAXIMA's Avatar
How about some pictures from afar?
Old Nov 25, 2008 | 09:45 PM
chernmax's Avatar
They came with the tape already on them and a small jar of adhesive promoter/cleaner...
Old Nov 25, 2008 | 09:52 PM
chernmax's Avatar
I don't live in a contaminated environment...
Actually the mesh filter style is the same as the K&N and the APC is also washable like the K&N. I really like the better clearance and I really thing the APC can suck in air better then my K&N. You know me, try it and if it doesn't work out, I'll change it again. My Turbo wideband A/F monitor seems to like it!!!
Old Nov 25, 2008 | 09:54 PM
chernmax's Avatar
I'll get some up tomorrow outdoors, it was already dark outside when I got finished so those pictures were taken in my garage...
Old Nov 25, 2008 | 10:06 PM
!PrjctMax!'s Avatar
Sucking more air in=not filtering as well...right?
Old Nov 25, 2008 | 10:47 PM
Icons04SilverMax's Avatar
Looks like these are the eyelids... http://www.autoaccessorystore.com/ho...=14&mid2=25271
Old Nov 25, 2008 | 11:45 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
yep... loooks like them...
wish i would have found those... i hate paradox .. bad cstmr srve
Old Nov 26, 2008 | 04:23 AM
nysmaxima's Avatar
chern...your max never ceases to amaze, great look...can you post some info on the oil catch can install...where does it go...what parts needed etc.....thanks (stock setup)
Old Nov 26, 2008 | 04:34 AM
ramberg's Avatar
GrandPa
Looks good my friend. Keep up the good work.
Old Nov 26, 2008 | 05:16 AM
goon9's Avatar
Are those toyota bolts on your valve cover?
Old Nov 26, 2008 | 05:30 AM
chernmax's Avatar
[quote=Icons04SilverMax;6724469]Looks like these are the eyelids... http://www.autoaccessorystore.com/ho...271[/quote]
Thanks for finding it, that's exactly where I bought them at!!!
Old Nov 26, 2008 | 05:36 AM
chernmax's Avatar
Thanks for the feedback, but normally I like a little more than 12 hours of evaluation...
As far as filtering, and based on the location, risk in minimum!!!
Old Nov 26, 2008 | 05:44 AM
chernmax's Avatar
If you have a stock setup you don't need an oil catch can. Turbo's tend to vent off more oil. With a stock ride the oil is so minimum it gets vented back into the intake manifold assy and burned off. With a Turbo, too much oil being vented back into the intake can lead to slimy oil build up and eventually lead to grimy internals and affect airflow.
Old Nov 26, 2008 | 05:46 AM
chernmax's Avatar
Unless that's what Nissan uses??? Those bolts are stock!!!
Old Nov 26, 2008 | 09:52 AM
goon9's Avatar
Interesting, I thought only toyota used the dimple headed bolts.
Old Nov 26, 2008 | 10:25 AM
chernmax's Avatar
Learn something new every day!!!
Old Nov 29, 2008 | 07:38 AM
po8pimp's Avatar
Hey chern how's your tranny holdin up since the rebuild? Also are there any plans for another turbo in the near future? Twins are allways nice.
Old Nov 29, 2008 | 08:17 AM
chernmax's Avatar
No problems on the tranny, still holding up great!!! I'm also not abusing it so that may be a factor and anytime I need it, BAMN down the road Red Heat moves!!! Twin Turbo, no added value with a front wheel drive IMO...
Old Dec 2, 2008 | 04:37 AM
nysmaxima's Avatar
chern...thanks for the catch can info...sorry for delayed response was out of town...
Old Dec 2, 2008 | 04:51 AM
AceofSpds's Avatar
wat
Why do you have a catch can and then a breather? That makes no sense to me why people do that. Why not return it to your intake manifold instead of it going to the breather.
Old Dec 2, 2008 | 05:10 AM
chernmax's Avatar
Please reread post #19
Old Dec 2, 2008 | 05:59 AM
AceofSpds's Avatar
wat
Yes i know what is stated in the post.
But why would you have the catch can if the crankcase air is just going to get released into open atmosphere.
Edit: I guess ill re-elaborate what im getting at. On a properly setup crankcase vent system the air is flowing OUT of that hose and to the Catch can correct? Then Continues flow outward to your filter there and out into open atmosphere. What is the point of catching oil particles that are already outbound when they are not going to be doing any harm. Except possibly a slightly more grimy engine bay. The catch can would be doing you more benefit if it were between your intake manifold and the VC. And not between an open element filter and VC.
Old Dec 2, 2008 | 06:20 AM
Torgus's Avatar
because it's not...
Old Dec 2, 2008 | 09:44 AM
Prophecy99's Avatar
nothing but the best....
Old Dec 2, 2008 | 12:50 PM
chernmax's Avatar
With My Speed Force Racing Turbo kit, a small filter was sent to replace the hose from the crankshalf vent which then vent into the engine bay, well that soon got oily and yes it started blowing back residual oil into the engine bay and I love a clean engine so I custom made ($25) an oil catch can to trap the oil and still allow proper venting. So to elaborate, it was a cleanliness thing for me.
Old Dec 2, 2008 | 01:51 PM
KC2010's Avatar
I like those eyelids. I just bought myself a christmas present. Thanks! I think I can explain to the wife that since these allow the car to be more aerodynamic it will help the mpg. HA!
*I need a bib cause my BS runneth over*
Chris, how long between purchasing and them sending them did it take for you?
Old Dec 2, 2008 | 02:24 PM
SpooledVQ35's Avatar
pvc is on the rear valve cover. That is where most of the blowby is...
Old Dec 2, 2008 | 08:24 PM
chernmax's Avatar
I got mine in 5 days!!! And if all else fails with the wife, Deny, Deny, Deny!!!
Old Jan 17, 2009 | 07:04 AM
Maxipad's Avatar
I can not find any eyelids for my 07. Somebody gota have them or know were i can gt em.
thanks
sadela
Old Jan 17, 2009 | 07:39 AM
po8pimp's Avatar
thanks
sadela
First I wanna say welcome to the org. Second I love the name.... Ohh and to answer your question I did a search and couldn't find anything for the 07-08 model. However you can do what I have done and make a template of what you want and go to a shop that does signs or even one online and have them make you them. Bluebat I believe also sells them, not sure if they are for the 07 and 08.
Old Jan 17, 2009 | 07:52 AM
Maxipad's Avatar
Thanks!
Old Jan 17, 2009 | 08:11 AM
chernmax's Avatar
Bluebat's are vinyl though, not like mine shown!!!
Old Jan 17, 2009 | 10:11 AM
po8pimp's Avatar
ohh those eyelids look like my vinyl sidemarker covers. either way awesome addition. if no one sells them vinyl should do just fine. easy to make and cheap too. My sidemaker covers were $14 so I tipped the kid who put them on like $20 to do it. Plus he showed me how to do it and gave me extra vinyl enough to do about 2 more sets of sidemaker covers. Soap and water and a piece of cardboard to smooth out bubbles. then a hair dryer or the sun to dry them. not too close with the hairdryer though.
Old Jan 17, 2009 | 01:15 PM
Mu33rto's Avatar
nice pics
