is the SECU on the 20th AE different than the other models?
Old Dec 2, 2008 | 01:08 PM
imported_D_Roc's Avatar
installing a starter on my 01 maxima the starter part is fine, but the keyless entry is where i'm really confused, i downloaded severl wiring diagrams and and the one at the A/V section, all the wiring diagrms are the same. but it doesn't match wiht my SECU 's harnesses.like in the diagram says that Power Lock is a brown and yellow on pin #35 but the pin number 35 is empty and but there is a brown and yellow wire at pin number 14. so the correct color wires are there but not in the place where it says should be on the wiring diagram. so is there any way to check the wire using a multi meter
i need to find the wires for
Power Lock
Power Unlock
Trunk Relese
Factory arm
Factory Disarm
Dome light supervision
all these at the SECU
Old Dec 2, 2008 | 03:41 PM
VQP0WER's Avatar
Did you get the bypass module?
You can test for 12v with a probe. It will look like a sharp needle at the end with a little bulb and alligator clip. You pierce the wire insulation and if the light goes on, you have 12v.
Old Dec 30, 2008 | 04:43 PM
loveofmylife00maxima's Avatar
i suggest bringing it in to a pro cos i just messed up my SECU trying to do that
Old Dec 30, 2008 | 04:55 PM
perkman87's Avatar
Last Time I went probing around with a volt meter. I had to have it towed to the dealership. blew 12 fuses and did not think to check. just be careful.
Old Dec 30, 2008 | 05:20 PM
VQP0WER's Avatar
Some of you should not touch a tool then......haha
Old Dec 30, 2008 | 05:29 PM
nsnrider's Avatar
this thread is almost a month old, i'm sure the OP found out his dillema by now.
Old Dec 30, 2008 | 05:37 PM
perkman87's Avatar
sorry I honestly just wanted to see my new sig lol.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Dec 12, 2015 09:39 AM
ivorton23
Sep 28, 2015 09:08 PM
ik95
Sep 16, 2015 08:11 PM
