HID in Fogs (H3 vs H3 mini)
Anyone have the h3 mini or h3c as they call them in there fogs?
For those without the minis, are your hid bulbs hitting the glare shield, bout to buy 6k for the fogs but i was concerned about fitment.
thanks for the help
M
thanks for the help
M
I've had every H3 type out there. The H3C fits perfect, the H3 mini fits good, and the regular H3 fits a bit tight, but will do the job. Although the H3C fits perfect, the color is a little bit off due to the bulb being so small and i believe they only make 6k & 8k for them..anything else..just let me know..
Mine touch the reflector, still don't have a problem, I have 3k now and about to change back to 6k, cant get use to the yellow. By the way, you can get the H3C's from Operatic, that is where i got mine, but like i said, the 6k is not going to match perfectly.
I have no idea how you guys are fitting H3's in your 5.5 gens??
I had to send the h3's back for H3c's -- H3's were WAY too long to fit with the glare shield in place!
...and for those who are removing the glare shield: You've simply created a HUGE GLARE POD!!
Now that's dangerous - let alone, counterproductive.
I guess you could try the H3's, but to me - only the H3c's fit PROPERLY without resting on the shield.
gr
gr
removing the glare shield has not caused me problems. i aim them lower than they should be so not to be in other cars eyes but them being hids still gives me much better vision and distance than the halogens originally in there.
i havent once been flashed. Ive had some one drive my car as well so i could see if they needed to be adjusted lower and such,... and i was in another car. was no glare and at the setting they are at still give great output.
gr
gr
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
I just ordered a 3000k H3 HID kit for my Max.
