Did I damage the tranny?
We got whacked with some major snow, and as a result my car got stuck for hours on my street. It took an hour of revving and wheel spinning just to get the last third of a mile to my house.
In the midst of all this my ABS light and TCS off light are on and everytime I start the car the Check AT light flashes for a good 15 seconds. Anyone know what's wrong? I haven't driven the car anywhere to see if the lights will turn themselves off cause I'll just get stuck again. The tranny light really worries me. Have I damaged anything?
When I got into my driveway I tried reving it lightly to 3k and as the rpms fell I could hear a distinct rattle, and it wasn't pinging either. Anyone know what's wrong?
not sure if this can happen or not, but you might have a crap load of snow where the abs sensors are so that might throw the abs light on,
Check your tranny fluid, see if it is still bright red, it's probably brown now, see if you can tell if there are metal shavings in there as well.
With the automatic transmission, on the gear selector, look at the upper left corner. You'll see a tiny slot, pry that plastic finisher up with a tiny flat blade screw driver and use that screwdriver to push in the shift lock. Make SURE you are on level ground OR have the parking brake set.
You can switch the gear from Park into Neutral which will cause the car to roll!
yea my stock y-pipe heat shields rattle....that will all be taken care of when finally get that replaced with a cattman...and to make my p0430 go away, im going to get a Eastern catalytic precat
litch
123
Jan 4, 2024 07:01 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
