Performance Problem
Performance Problem
Ok, my car has gotten slower recently. There's a noticeable difference from the driver's seat, as it takes much longer to get through the gears on WOT. Also at the track, I've lost as many as 5-9 mph off of my trap times and almost a full second off my quarter mile times. My check engine light is on because of the headers I have. I got the codes pulled, and what came up was the two O2 sensor codes and P0300, which is a cylinder misfire. The cylinder misfire isn't the problem, because this problem just started recently, and I've had that code ever since soon after I put the headers on. Originally, I was thinking it was the MAF, because that seems to be the official maxima.org solution for 90% of all performance problems... but there were no codes for the MAF. So what could the problem be?
It is the flap/valve in the upper intake manifold that opens/closes to change the flow of air through the IM to provide better lowend torque and better topend power - do you not notice the audible change it's around the 4k rpms mark, you should also feel the dip/change in power as it activates allowing better topend - if you look at a dyno chart you will see this function occuring.
Sorry my connection to the forum is very sluggish so was unable to edit my last post. I did want to add that it is vaccuum controlled, you will see the vaccuum leads coming off the left ( passenger ) side of the upper IM -- check all the vaccuum lines as mine was not functioning properly and it was b/c of a leak in one of the lines.
Once Again unable to edit my post after seeing your response, sorry!!
Nevermind that, did not know you took the VIAS out. Hmm, is there a way to test out your timing while running the car - do you have any laptop obd2 type software? or any friends w/ OSIRIS? (Titan truck dudes run this and it can read some diagnostic info from your ecu)
You don't have any vaccuum leaks around the IM that may have opened up? How old are the o2 sensors? I'm not quite sure what could cause such a tremendous powerloss, something must be causing a huge drop in timing. Have you tried to reset your ecu at all? Do you have a bad tank of gas? Just throwing out some random suggestions..
but if that were the case, then wouldnt the car have been running poorly right after i put the headers on? i had a good while of nice performance with the headers before this sluggishness started
i have no idea how old the O2 sensors are.. the problem actually started when i went to the track and did some runs after putting in some "octane booster" fuel system cleaner from pep boys on about a quarter tank of gas.. i dont remember the name of it, but it was in a red bottle.. you think that could have screwed up something?
as a good rule of thumb you should do whatever needs to be done to clear your codes and then take things from there when you are having problems. my guess is you are running rich because of your o2 code which has over time been fouling your plugs which would explain your misfire and the lack of performance.
that being said cleaning your maf is a good pice of preventative maintenence which may help your situation...
http://forums.maxima.org/5th-generat...10-w-pics.html
gas mileage is pretty good.. it's gone down a little bit from increased idling times with warming the car up for the winter.. other than that, it's pretty much on point.. i have a 2001 maf from my old car sitting in my basement.. so im gonna try taking that wire from my 2003 MAF, putting on the 2001 MAF and seeing if that makes a difference
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
