loose carbon in charcoal canister
Got the P1445 evap code a while ago, reset ecu replaced gas cap, checked the volume valve, all the hoses and the code came back.
So i decided to take a look at the canister. Before taking it out I decided to knock on it with a wrench and it sounded like its full of sand inside.
Are the carbon inside suppose to be loose or is it simply broken? thanks for the help
maybe this helps u solve ur problem for the code
http://boredmder.com/ecucodes/index....1999&DTC=p1448
depending on the year p1445 is the code for the purge volume control vavle, it is right on top of the intake manifold, it has 2 hose;s coming from it and is a 6 pin connector. veery easy to replace. i can tell u this since i have had to deal with that code and replaced that part to have it fixed good luck.
http://boredmder.com/ecucodes/index....1996&DTC=p1445
DC_Juggernaut
Sep 28, 2015 04:07 PM
