New Racingline FSTB
Old Feb 2, 2009 | 03:48 PM
eric_holmes's Avatar
New Racingline FSTB
I finally got a chance to get this thing put on. I still have to trim up the side panels. Tell me what you think
My new nismo oil cap.
Old Feb 2, 2009 | 03:50 PM
Here is what I need input about... Does this look right to you? Can the line touch the bracket? I tried to bend it but thats all I could do. Does it need more?
Old Feb 3, 2009 | 09:36 AM
TAZ's Avatar
TAZ
you have 2 options, 1) unclip the line and place it in front of the white clip or (2) slightly bend the gold bracket a touch flatter to push the line forward. Looks good though!
Old Feb 3, 2009 | 09:42 AM
nene503's Avatar
I was wondering the same thing about the AC line and I would love to get some info on what you did and how you did it.
Old Feb 3, 2009 | 11:54 AM
BigPete's Avatar
Incognito
looks good. The AC line is hit or miss. Some of us had to bend it, some didn't.
Old Feb 3, 2009 | 01:25 PM
I uncliped the white thing and moved the line in front of it. Ill post pics up.
Old Feb 3, 2009 | 03:06 PM
New Pics...
This one shows the white clip and the A/C line.
Does anyone have a problem getting this "push pin" in there?
Old Feb 3, 2009 | 05:16 PM
I VIK I's Avatar
Im deciding between the silver and the black, anyone have pics of the silver?
Old Feb 3, 2009 | 07:11 PM
Old Feb 3, 2009 | 08:35 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I have a Stillen FTSB but they have a similar issue. I removed it from the plastic clip and as an added safety precaution I used a zip tie and secured it to the bigger line to the right which tends to pull it away for no chance of rubbing!!! ~0_0~
Old Feb 3, 2009 | 08:38 PM
chernmax's Avatar
Damn man who cut up your ride side plastic cover??? That was hacked!!!
Old Feb 3, 2009 | 08:51 PM
Machinist's Avatar
Old Feb 4, 2009 | 04:23 AM
I took those pictures from a search. That hack job isn't mine lol.
Old Feb 4, 2009 | 07:27 AM
VigilanteMax's Avatar
he knows whose car that is
Old Feb 4, 2009 | 08:38 AM
Staggered357's Avatar
I just ordered my polished FSTB last night can't wait till it gets here...
Old Feb 4, 2009 | 08:44 AM
Mikesima's Avatar
Hahaha! Killer trim job man!
I just IM'd you and saw this thread.
Old Feb 4, 2009 | 10:15 AM
KC2010's Avatar
I used a small black zip tie to keep it further away from the bar. Also, I placed a piece of electrical tape on the back side of the FSTB in case it ever decided to rub.
Old Feb 4, 2009 | 10:16 AM
KC2010's Avatar
Yes, I just left it as is.
Old Feb 4, 2009 | 10:18 AM
KC2010's Avatar
It looks like it might be Dues' old custom intake and yellow top pic (notice the red lettering). Dues, is this your hack job?
Old Feb 4, 2009 | 11:10 AM
Machinist's Avatar
Get them all in before locking the first one
Old Feb 4, 2009 | 11:30 AM
Thanks for the compliments guys!
Old Feb 4, 2009 | 12:34 PM
Machinist's Avatar
I drilled a new hole in the gold colored bracket
[I put a small piece of scrap wood under it while I drilled so I wouldn't drill into the inner fender]
the new location of the white clip that holds the AC line in place is now more toward the
engine & the front of the car so now there is more clearance at the AC line & the FSTB
Old Feb 4, 2009 | 12:40 PM
Originally Posted by Machinist
I drilled a new hole in the gold colored bracket [I put a small piece of scrap wood under it while I drilled so I wouldn't drill into the inner fender] the new location of the white clip that holds the AC line in place is now more toward the engine & the front of the car so now there is more clearance at the AC line & the FSTB
Good fabrication Machinist, so I put in the missing clip first and then tried to put the others in, still no work. That empty hole just bugs me. The plastic piece is hitting the strut bar mount and wont let the piece go down all the way. Any suggestions? I thought of grinding the mount down just a little.
Old Feb 4, 2009 | 01:10 PM
Machinist's Avatar
^ Try this, loosen the mount [there should be a little play in the mounting holes]
& relocate for the needed clearance. Grinding may the only answer tho
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
2000MaximaSE
Dec 12, 2000 10:35 PM
