resistors, and LED positive and negatives
Old Nov 18, 2001 | 04:01 AM
ngthing's Avatar
how do i know which side is which? and how do i hook up my resistors to the LEDs?
Old Nov 18, 2001 | 10:17 AM
Stereodude's Avatar
Re: resistors, and LED positive and negatives
The side with the longer lead is the positive side. There should also be a flat side on the LED. The flat side is the negative side. the best way to hook the resistor to the LED is by soldering it. Depending on your soldering skills there are several different approaches. If you suck at soldering make a hook on the lead of the LED and on the resistor. Then interlock the hooks and add some solder to hold them together. If you're a skilled jedi solder expert then you just lay the two leads side by side, heat them up and add solder.
Stereodude
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
