rattling noise
Old Mar 17, 2009 | 01:09 PM
liljr415's Avatar
rattling noise
hey u guys im hearing a rattling noise on the inside of the car when i drive on bumpy roads i think it might be coming from the passenger window or somewhere near there anyone had similar problem let me know thanks
Old Mar 17, 2009 | 03:29 PM
Wantastic's Avatar
yeah i have that too. it comes and goes. i haven't had that noise for a while and it's not that loud so i just ignore it. it could be something stuck under the seat or so.
Old Mar 17, 2009 | 03:43 PM
Feldman's Avatar
there are a lot of potential spots for rattles, the best option would be to have someone ride in your passenger seat and they can help you track down the location of the rattle
Old Mar 17, 2009 | 09:45 PM
MaxEx's Avatar
I may know what it is if it sounds like it's coming from the passenger side door area. Check the outside metal stripping on the bottom of the door. Mine is still loose and it rattles occasionally going over bumps.
Old Mar 17, 2009 | 09:52 PM
BLACKNESS MONSTA's Avatar
Not to thread jack but my center arm rest and third brake light rattle all the time...
Is there a fix?
Old Mar 18, 2009 | 03:45 AM
ramberg's Avatar
GrandPa
Is there a fix?
Check out the sticky's or do a search.The answers are there.
Old Mar 18, 2009 | 03:46 AM
ramberg's Avatar
GrandPa
I would check the strut.
Old Mar 18, 2009 | 05:53 AM
reb's Avatar
reb
Check and re-torque the front end stabilizer links. There was a TSB that covered my production date.
Old Mar 18, 2009 | 09:55 PM
All the veterans always mention that lol but in reality the search button sux.
I've had better luck searching this forum w/ google...i jus type "6th generation maxima (insert search word)" lol. But newayz...
Old Mar 26, 2009 | 07:56 PM
sodomojo's Avatar
I agree, I try to search and lately have been getting no results.
Old Mar 26, 2009 | 09:09 PM
liljr415's Avatar
i know for sure its coming from the window i pulled down the window and i feel that it is loose is their anyway to tightened it or should i take it to the dealership
Old Mar 27, 2009 | 08:10 AM
Lovemycar's Avatar
I got the same noise I beleave it's the door aswell
Old Mar 27, 2009 | 11:28 AM
cklamer's Avatar
Okay I live on roads that are very rough and drive them at least 3 miles a day and I have figured out that one place I get a rattle from inside the car is the domed part that goes over the instrument cluster (speedo-tach) because I am on the road long enough so I can put a hand on that part and it goes away and when I move my hand it starts back up.
The only other rattle inside of the car has been in the seat belt area where you can adjust the level next to your left shoulder.
One other thing everyone needs to look under the front of your car and check the plastic panel that covers the underside of the engine compartment (keeps debris out of the engine compartment) because mine almost completely fell off. The only things that hold this own are the same lousy little clips they use to hold on the strut tower covers and you know how easy those are to remove. The only reason mine didn't come completely off was they used screws on the front part when they replaced my front bumper and the only thing holding the back part is about 6 of these clips. So just a little FYI.
Old Mar 29, 2009 | 05:54 PM
Lovemycar's Avatar
Ok the noise is coming from my front passenger seat when I hit a bump it shakes enough to make a rattle noise like it's loose on the track it doesn't do it when I hold the seat does anyoone know how to fix this
Old Mar 29, 2009 | 06:04 PM
Bakermax's Avatar
That kind of stuff drives me nuts, my 4th gen is like a tank, but my 00 rattles and squeaks all day. This doesn't apply to your gen, but you may find some of it useful.
http://www.fourthrock.com/maxima/issues/issues.html
Old Mar 29, 2009 | 10:54 PM
liljr415's Avatar
i will have the dealership check it out when i get my next oil check which is next week i will let u guys know if they fix it but still any suggestions are appreciated
Old Mar 30, 2009 | 04:30 PM
liljr415's Avatar
thanks for taking the time to explain man it really helped out my set belt adjust thing was a bit loose and i tightened it tomorrow when i go to work i will see if i still hear the rattle
Old Mar 30, 2009 | 06:27 PM
Lovemycar's Avatar
I'll check that tomorrow
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
