watts ohms ????
Old Nov 19, 2001 | 06:12 PM
bryce's Avatar
watts ohms ????
if i wire a speaker thats 8ohms parrallell with a tweeter thats 4ohm i get a 2.66 ohm ,right,correct me if im wrong.
now if my amp puts out 100 watts @2ohm , how many watts go to the speaker and tweeter
Old Nov 19, 2001 | 07:28 PM
Yellowbrother's Avatar
Re: watts ohms ????
general rule is that when u wire anything in parallel...ur total resistance(impedence) is less then ur smallest value...here is the equation: [1/{(1/r1)+(1/r2)+(1/rx)}]=total resistance when wired parallel...
Old Nov 19, 2001 | 07:41 PM
bryce's Avatar
so .... is 2.66 ohm right or wrong and how many watts will the speaker n tweet get
Old Nov 19, 2001 | 08:23 PM
do the math son...i gave u the formula...hehe...j/p...yeah it's rite...and since it is wired in parallel...according to ohms law...the one with lower resistance (impedence) should get more of the power...as a matter of fact the 4 ohm should get twice the power of the 8 ohm...correct me if i'm wrong someone...it's been a while...ohm's law is kinda shaky in my head rite now...
Old Nov 19, 2001 | 08:25 PM
Coldboot-SE's Avatar
Yes and No
If this was a strictly resistive circuit yeah an 8 ohm and 4 ohm in parallel would be 2.66 ohms BUT this is a reactive circuit meaning AC
and different frequencies.
No one in their right mind would wire a 8ohm speaker with a 4 ohm tweeter without a crossover, even if it was only a 6db cap. where your amp would see more of the 8 ohms below the xover freq and 4 ohms above.
BTW
Watts = I (current)^2 x R (resistance) or
Watts = I (current) x E (Voltage)
Old Nov 19, 2001 | 08:50 PM
jmax
I'll second that. Don't worry about ohms law untill you have something that can be hooked up. Tweeters are generally more efficient than mids and woofers so usually have a resistor somewhere to balance the output of the larger driver. As it is your tweeter will blow about the same time you get the volume **** to the point where you can just hear the woofer.
jmlee44
Oct 2, 2022 02:13 PM
kjlouis
Nov 24, 2018 06:09 AM
vybz05
Dec 10, 2015 07:38 PM
bryants95max
Oct 2, 2015 12:52 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
