slow cranking
slow cranking
My car start cranking slow(had to hold the key to get it started) now its not cranking at all, i replace the starter and battery im out of ideas on what it can be. Do anyone have any ideas
It was cranking slow now its not turning at all (well i can here a tink sound coming from the starte).
I can get the cables and touch the battery and it will turn, its like its not enough power coming from the car to turn the starter.
i check for corrosion and test the battery and i have new connection
I check the cable from the fuse box under the hood to the starter. i sent power from the fuse box to the starter and it started
Maybe the reman starter is bad - I had to return 2 remans before I finally bought the brand new one that works perfectly. The remans installed did the same thing, they would either just click or not click at all until finally one of them burn up in smoke. Some of the remans may have worn out solenoid assemblies, from previous users.
TKHanson
Nov 24, 2018 01:39 AM
Andy29
Sep 29, 2015 05:32 AM
