Disabled fuel pump - still getting fuel?
Old Apr 21, 2009 | 11:12 AM
Maximan190's Avatar
Im getting ready to pull my motor soon, and i go to disable the fuel pump (pulled the fuse with motor running) to suck the fuel lines dry. However this doesnt completely empty it out as i still have a considerable amount of gas in there since the motor will still turn over, and a nice gush of it spills out when i go to disconnect the lines in the engine bay
Now im thinking im either doing something wrong, which i dont see how since this has worked in the past.... i pull the fuse and starve it of fuel - car dies and never starts back up again
Maybe the fuel pump is bad? Its only about 2-3 years old though
Putting 2 and 2 together, maybe or maybe not this has something to do with my other long time problem which is cylinder 1 getting an excessive amount of fuel - I cranked the motor with the plugs out and splashes of fuel shot out of cyl 1 only, and periodically cyl 1 does not fire. The injector is still delivering fuel since the exhaust smells incredibly rich. Plug and coil are both fine
I was originally blaming a leaky/bad injector for my cyl 1 problem, but both issues above considered, thoughts?
Old Apr 21, 2009 | 11:22 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i wouldn't be surprised if you just didn't start it enough times to drain the fuel. i would have been revving it when you pulled the fuse, that way it would have had the injectors wider open and would have run longer before stalling out.
Old Apr 21, 2009 | 11:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
sure and run lean and make it knock/ping...smart idea.
Old Apr 21, 2009 | 11:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
usually after the car stalls you crank it a few more times and it'll fire for another sec or two. when you pull the fuse there is still some fuel in the line left so that's why you get some injector splashing.
Old Apr 21, 2009 | 01:24 PM
i didn't mean hardcore revving, just enough to keep above 1500 for the 5 seconds that it stayed running. would that little amount of extra throttle, under no-load, be enough to still make it ping?
Old Apr 21, 2009 | 01:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
what's the difference between "hardcore revving" and "revving"?
DON'T REV IT AT ALL.
X amount of fuel that's in the fuel line will be pulled into the engine. stepping on the gas will do nothing since the fuel pump is not running (fuse out). the residual pressure in the fuel line will feed the engine until the pressure drops below a threshold that can't push fuel into the engine anymore. the residual fuel is what OP sees or got sprayed with. additional cranking will attempt to reduce the pressure more.
with revving...all you're doing is causing it to go lean since you're adding air and not fuel. this might cause a ping or knock if the engine is running poorly to begin with.
following the FSM procedure and don't tell people these 1/2 baked procedures.
Old Apr 21, 2009 | 01:42 PM
i thought that more air going through the MAF would make the injector stay open longer per cycle (just like it would under pressure) thus releasing the residual fuel in larger quantities at a time.
i've never done it that way before, it was just an idea i had. but now i know not to try it. sorry to give bad info
Old Apr 21, 2009 | 01:45 PM
maximaman1313's Avatar
I had this exact problem, minus the cylinder 1 issue almost a year ago.
I pulled fuel pump fuse while car was running. car died. and EVERYTIME I restarted it the car would fire up and run from anywhere from 30seconds to longer than a few minutes.
I still have no idea what caused so much fuel to continue flowing through the lines. After 1 hour. yes, 1 full hour, I finally said **** it and pulled the fuel line off the fuel filter and put a screw in it to plug it.
I have no clue why my motor would be able to run for minutes at a time with the fuel pump fuse pulled. It didnt run smoothly but it would run bouncing from 300-800 rpms for alot longer than it should.
good luck. im curious as to if you find anything out with your car thats giving you the issue.
wish I had usefull info for you
Old Apr 21, 2009 | 01:46 PM
DanNY's Avatar
Ad·min·is·tra·tor
normally it would...from adding more fuel from the pump and causing a vac (open up the regulator)..but you have no fuel pressure. injector can click wide open and nothing will happen.
Old Apr 21, 2009 | 01:47 PM
DanNY's Avatar
Ad·min·is·tra·tor
it doesn't take much fuel to idle a motor.
also there's a lot of plumbing for the residual fuel to stay in.
Old Apr 21, 2009 | 01:54 PM
Obsession_92-94's Avatar
This is sort of a stab in the dark as I have not really had any fuel line experience (yet), but could it be that fuel is leaking due to a siphon? Figure that the pump had created a vacuum in the tank and it will continue to drain? Or maybe the weight of the fuel in the tank being forced out of the tube?
Old Apr 21, 2009 | 02:00 PM
ok, makes sense now
Old Apr 21, 2009 | 02:10 PM
DanNY's Avatar
Ad·min·is·tra·tor
yes it's very possible...but keep in mind there's going to be very minimal pressure behind it. so when you pull the hose off the filter or whatever it'll trickle out still but it's not like full force spray. i parked a car on a slant down hill and the fuel never stopped leaking out. gravity pull the fuel down to the engine.
when you pull the fuse you're basically reducing pressure in the line so it doesn't spray in your eye (been there done that).
Old Apr 21, 2009 | 02:21 PM
Maximan190's Avatar
^ What you described is exactly whats happening to me.. it keeps idling low and on the threshold of stalling
I see your points danNY, and the others for the input.. I will try to let it empty out as much as it can. I just thought i could have pointed a finger at my mistakes (if any), the fuel pump, fuel pressure regulator, etc
However my cylinder 1 misfire issue is still a mystery then
Old Apr 21, 2009 | 02:32 PM
DanNY's Avatar
Ad·min·is·tra·tor
lazy injector or one w/ a bad connector?
it might be stuck open or sticky.
Old Apr 21, 2009 | 05:24 PM
kringle03's Avatar
This is the procedure that I follow:
Remove FUSE.
START car.
Car DIES.
REMOVE fuel filter.
REPLACE fuel filter.
Replace FUSE.
START car.
I'm not sure why ya'll are trying to run the fuel system completely dry? It won't happen... you will leak fuel no matter how hard you try not to. The idea like Danny stated is to relieve pressure on the line not to completely empty it.
But who am I and what do I know, I'm just the 800lb gorilla in the room?...
Old Apr 21, 2009 | 08:32 PM
Maximan190's Avatar
lol 800 lb gorilla
Im disconnecting everything as im going to be pulling the motor... I just remember in the past i didnt have as much fuel spit out at me as i did in more recent times
ill keep the injectors that come on the JDM motor & probably have them spray tested so hopefully this problem will dissapear.. I hope it is the injector itself and not something ECU/wire related
Old Apr 21, 2009 | 09:08 PM
not very often do the ecu's go bad, but they can.
have you ohm'd the injector in question?
Old Apr 21, 2009 | 09:19 PM
1993-VG30E-GXE's Avatar
lol 800 lb gorilla
Alot of fuel comes out. I did the procedure you guys said...run it first then remove fuse while running...then try to crank again...it did it the 2nd time but started for like 1 second the died, but like d-money said, there's residual in the pipes. Remove send & receive lines, fuel leaked out. I just lifted out the rail assy an hr ago, and lots of fuel started coming out of the pipes...enough to make a small puddle on the ground.
Oh, to the dude who recommended I replace the little fasteners, here's the spec for the 4 fuel rail bolts if you need to buy ahead of time:
M8X20 Socket Cap Coarse Incl. M8 Lock Washer & M8 Washer
Qty = 4
Old Apr 21, 2009 | 09:24 PM
Qty = 4
you could have plugged the rail inlet/outlet with your fingers to prevent further spillage. i often stuff a bolt in lines that i don't want leaking. did you unscrew your fuel cap too? sometimes i think that helps keep the fuel from leaking AS much. i heard the vapor pressure in the tank can will cause more spillage even after the pressure in the lines is basically gone.
Old Apr 21, 2009 | 09:28 PM
Garf's Avatar
Even if you had a faulty injector, i don't think that one (1) injector would keep the engine running four minutes..hours.. etc. Like Kringle mentioned, I always pull the fuse BEFORE starting the car, I don't know what all this talk about pulling the fuse while the car is running is aout, or if it even makes a difference?
Old Apr 21, 2009 | 09:40 PM
I did the remove the gas cap thing, but I can't remember if I did it before or after I removed the fuse. Next time I should just leave it off maybe.
Reason I wanted to drain it all out into the puddle, was I was bringing it in the house....so I wanted it all to leak out. Same with the water hose for throttle body (hose under dual duct)..when I point it down, it seemed like it kept leaking coolant, point it up, it stopped. It was as if it would keep leaking all my coolant out how fast it was coming out.
Old Apr 21, 2009 | 10:17 PM
kringle03's Avatar
Well I don't know about motors in the house... that's a garage/outdoors event in my mind... but I guess you can do what you like... but don't expect a 16 year old engine to "not" leak anything when you do....
Old Apr 21, 2009 | 11:52 PM
Really? I don't think bringing the fuel rail into your house is that risky.
Old Apr 22, 2009 | 12:20 AM
haha no he thought you were bringing the whole ENGINE inside
Old Apr 22, 2009 | 05:35 AM
kringle03's Avatar
lol yeah my bad... I was under the impression that you were pulling the engine in hopes of bringing the whole thing inside to work on...
Old Apr 22, 2009 | 09:30 AM
his injector #1 issue is not related to the engine runnin after fuel fuse is pulled. it was a seperate issue the op also mentioned
I dont think it matters when you pull the fuse.
Old Apr 22, 2009 | 11:35 AM
Garf's Avatar
...I dont think it matters when you pull the fuse.
Are you sure? I always pull the fuse before starting the car and unscrew the gas cap and there's no pressure in the fuel lines, it just dribbles out like water from a hose that's turned off.
Old Apr 22, 2009 | 11:45 AM
Im not 100% sure, but I have done it while car is running, and before i started the car(different instances of course), never noticed any difference or problems.
ive never thought to unscrew the gas cap, that could be why theres a bit more pressure on the lines
Old Apr 22, 2009 | 12:20 PM
James92SE's Avatar
2 VE's are better than one!
Hmmm, I've never done this running engine dry of fuel thing. Not on either of my Maxima's or the Honda. What's the point? Just to avoid spillage when taking the engine out?
If you're going for a 100% spill/leak free engine removal, could you cap the lines with those little clamps commonly used on brake lines or something?
Old Apr 22, 2009 | 01:18 PM
hadman's Avatar
There's nothing like the sting of fuel in the eye. I tried spray paint last week. It was painful as hell, and I screamed like a little girl, but still not quite the same as fuel.
Old Apr 22, 2009 | 01:36 PM
DanNY's Avatar
Ad·min·is·tra·tor
out of 10 filter changes i MIGHT de pressurize the fuel line once.
but this was when gas was below 2 bucks. otherwise take it like a man.
Old Apr 22, 2009 | 01:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
LOL...try brake cleaner. it's worse than gas.
Old Apr 22, 2009 | 01:43 PM
Greeny's Avatar
¯\(°_o)/¯
I just pop the fuel line off and let her spray.. bunch of wussies..
Old Apr 22, 2009 | 03:00 PM
Garf's Avatar
oh ok, i thought i read someone saying that the reason it was still running was b/c 1 cyl was still firing.....
either way ohm the injector that is suspect of being faulty and if its out of spec (11-14 ohms resistance) replace.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
