EGR delete?
Old Apr 28, 2009 | 09:06 AM
Crusher103's Avatar
EGR delete?
I took the pain in the *** job of cleaning my EGR about 2 weeks ago, i was throwing the P0400 code, i found a rubber hose had also dry rotted so i replaced that aswell now, i have the P0400 code back after under 2 weeks, and quite frankly im tired of the EGR if I take the damn IM off again I dont want it to be because of EGR problems its such PITA thing to do. So can the EGR be deleted on the USIM without throwing codes, will there be and performance losses due to it? I heard in one thread somebody said just let the sensor dangle and it wont throw any codes but that just doesnt sit right. I need some clarification before i shoot the thing.
Old Apr 28, 2009 | 09:53 AM
MOHFpro90's Avatar
Let the sensor dangle and it wont throw any codes.
Really... Though I am running the 00VI, it makes no difference. The EGR is a separate entity from the IM. I capped the hole in the header, and I capped the hole in the IM. Took everything out, and let the sensor dangle.
Old Apr 28, 2009 | 03:10 PM
Crusher103's Avatar
so u used a block plate right, im looking for those and none are specifically made for the maxima obviously, so would the 300zx use the same sized block plate?
Old Apr 28, 2009 | 03:47 PM
Product_Of_Korea's Avatar
sheet metal and some rtv
Or hack off the egr tube and plug that up
Old Apr 28, 2009 | 05:01 PM
Crusher103's Avatar
i want to keep the egr unharmed incase i need to use it again one day
Old Apr 28, 2009 | 05:21 PM
pmohr's Avatar
No more Maximas...
I'm using a block off plate for a 3000GT, IIRC. Fits up to the UIM perfectly.
Old Apr 28, 2009 | 06:36 PM
Old Apr 28, 2009 | 06:45 PM
Crusher103's Avatar
im going to try the 300ZX block plates hopefully they fit aswell
Old Apr 28, 2009 | 07:05 PM
pmohr's Avatar
No more Maximas...
Originally Posted by locknuts
Yep. I found it bolted on to something when we were cleaning up the shop, they were just going to throw it away. I was looking at it...hmm...
I'll grab a pic the next time my UIM is off, I'm sure it won't be a week or so before it is again.
Actually now that I think about it, it may very well have been from a Z32. But IIRC it was bolted up to a precat, so
Old Apr 28, 2009 | 07:56 PM
good info to know although i dont have a usim anymore
Old Nov 28, 2009 | 10:59 AM
Jambi's Avatar
Dragging up an old thread here but how has the EGR delete gone? I know mine is pretty mucked up and rather than dealing with cleaning it all the time I would just like to delete it. It does raise a question...by deleting it would it cause for a hard cold start??
Mine is going to go through some changes but not all at once so it still gets to run as a pizza delivery vehicle during the changes...lol.
Thanx in advance
Old Nov 28, 2009 | 12:42 PM
Crusher103's Avatar
Since i know what a pain in the *** process it can be i should to a write up, but everything has gone perfectly for me as far as deleting the EGR, what i did was to take the sensor out of the tube and use a long bolt to plug the hole. just find a place to hang the sensor in my case i used the strut bar and let it dangle there so its not touching any metal to cause weird interferences. The EGR should block up again in no time at all because of the bolt obstructing the path but it will never throw a code again because the sensor is no longer there.
I have run the car like this for a couple of months but im doing a 3.5 swap now so i dont have to worry about EGRs anymore.
Old Nov 28, 2009 | 04:47 PM
pmohr's Avatar
No more Maximas...
Thanx in advance
No, it has nothing to do with cold start. Just remove everything, plug off the rear exhaust manifold, block off the port on the UIM, problem solved.
Why not just use the OEM plug for the exhaust manifold, and remove all of that extra crap?
Old Nov 28, 2009 | 06:49 PM
Crusher103's Avatar
meh i was lazy and i cut my hand when i was working on it so i said **** it and went and bought a bolt that would fill up the whole tube.
Old Nov 30, 2009 | 12:04 PM
Jambi's Avatar
pmohr did you just remove the sensor all together or just dangle it as well??
Old Nov 30, 2009 | 02:08 PM
Crusher103's Avatar
he let it dangle, if u remove it u will throw codes.
Old Nov 30, 2009 | 02:18 PM
ajcool2's Avatar
Yup thats what I did.
Old Nov 30, 2009 | 05:17 PM
pmohr's Avatar
No more Maximas...
Indeed, dangle dangle.
Old Dec 1, 2009 | 07:55 AM
cashoit's Avatar
Can any of u guys post a pic. THe EGR can be a PITA and i would love to see how its done. Thanks.
Old Dec 1, 2009 | 10:01 AM
pmohr's Avatar
No more Maximas...
Post a pic of what? There's nothing to post a picture of, as it's all gone; that's the entire point of removing it.
Old Jun 25, 2019 | 06:55 PM
maxprivate's Avatar
Black Lion
Bringing this back im wondering if anyone can help with this. I did the 3.5 swap and had EGR deleted in Nistune, the guy working on my car is saying I still need the evap canister purge valve and purge control solenoid connected with vacuum and plugged in to the harness.
I just have the Egr sensor dangling, and the green EGR solenoid connected. My question is whether I deleted this EGR in Nistune or not ( 95 ECU ) would I get any codes for EGR if I left this disconnected? I included a photo. Its the evap purge control valve and evap purge solenoid.
Old Jun 7, 2023 | 08:49 PM
WolfZ31's Avatar
hey what size bolt did you use? I'm gettin the code n I figured I'd delete this egr since I've done it on my 300zx already
RedfoxXx
26
Dec 14, 2010 08:53 AM
mystican
Oct 1, 2007 07:52 AM
Jokester66
Oct 24, 2006 02:45 PM
7EyesOpen
Mar 11, 2006 05:00 AM
