carbon fiber hood question...
Old Nov 22, 2001 | 07:06 PM
MAXIPADMAN's Avatar
i purchased a hood from fiberimages a while back, and i was just wondering....
1) has anyone with this hood figured out a way to prop the hood up via hood stands or hood lifts? I dont wanna warp my hood in any way.
2) is there some sort of rubber gasket that you can purchase to put on the front of the hood (sorta like a lip)? The hood fits fine, but i can see the tops of my headlights when it is closed. I couldnt see this when i had my stock hood on.
thanks in advance for any info you guys can give me!
ryan
Old Nov 22, 2001 | 08:26 PM
1MAX2NV's Avatar
The oem hood has rubber gasket above the headlights. You might able to remove them and install them on the CF hood. Few questions for you. Are you using hood pins? Did you install the windshield nozzles?
Old Nov 22, 2001 | 11:28 PM
MAXIPADMAN's Avatar
no, i havent had time to purchase hood pins yet. They are definitely on my "soon to get" list though.
As for the window washers.. i didnt want to cut holes in the hood and have it installed, so i removed the entire reservoir from my engine bay.
Old Nov 23, 2001 | 10:03 AM
Stillnmax's Avatar
Ummmm well i know im going to get my nozzles put in where the windshield wipers sit... kinda like on VW's i believe.... Gotta get Hood pins.......
Watch your hood as you approach 110mph .... it will do a lil dance for you ...
Old Nov 23, 2001 | 10:21 AM
MAXIPADMAN's Avatar
Originally posted by Stillnmax
Watch your hood as you approach 110mph .... it will do a lil dance for you ... [/B]
i dunno what you're talking about. Ive gone well over 110 (on a road trip for thanksgiving actually) and absolutely no problems with the hood. So far fitment of the hood has not been a problem.
Old Nov 24, 2001 | 04:03 PM
ODDJoB's Avatar
Can anyone post any pics of their car with the hood im very interested in buying one i was just wondering how it would look on my white max......also how much am i looking to spend and did you but it direct from the manufacturer?
Old Nov 24, 2001 | 04:57 PM
Stillnmax's Avatar
maybe its just me, Trenz grill does let more air into the engine bay... and it is "open" by the hood latch
Old Nov 24, 2001 | 05:00 PM
OgreDave's Avatar
i cant even contact fiberimages to get my hood replaced, its ****ing me off.
Old Nov 24, 2001 | 05:07 PM
1MAX2NV's Avatar
They should have a distributor only phone number. That's what you need to find out. How else could they fulfil new orders? Sometimes it's worth buying through a dealer or retailer. Stuff like this would been taken care off.
Old Nov 24, 2001 | 05:34 PM
MAXIPADMAN's Avatar
i dunno.. i bought mine through chestons group buy on maximadriver.com about 6 months ago. Maybe he can still hook you up. I have pics of my hood, but i dont have time to post them right now. If you give me your e-mail addy ill send them to you.
ryan
Old Nov 24, 2001 | 06:00 PM
RedMax95's Avatar
yes, its quite strange opening a hood without the supports, trust me i opened maxis, i dont know if it would warp, but dang that thing is light, i wouldnt worry about the nozzles, i never use mine, and i dont think they would even look during inspection, the y pipe is what would cause u to fail if anything
Old Nov 24, 2001 | 06:04 PM
Stillnmax's Avatar
Dave that sucks bro
Old Nov 24, 2001 | 10:34 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
I guess Im the only one here that has hood props on my CF hood. I used the stock props I drilled a hole in the frame part of the hood where the factory hood prop screws in then I ground a small slot in the inside of the frame so I could get a needle nose into the inside of the frame. Then I welded a nut and washer together and used a needle nose to hold it in place a I tightned the bolt on the prop. Be sure to use a washer on both sides of the frame so yu dont crack the fiberglass my washers are about 3/4 in diameter and the work fine. With the stock hood props and a CF hood you can lift it about * inches then it just flys up. Ive had them on for about 1 1/2 months and no problems!
Old Nov 24, 2001 | 11:05 PM
MAXIPADMAN's Avatar
you didnt have problems with the factory hood props warping the CF hood? I was told that they put too much pressure on the CF hood, and that it couldnt support them.
Old Nov 24, 2001 | 11:53 PM
TILLEYS99's Avatar
No they are fine the shocks only apply pressure when its upward but when its closed the shock are pushing the hood toward the front of the car rather than towards the sky, basicly the props have no leveridge upward when the hoods closed. when the hood closed the props are parallel with the hood.
Old Nov 25, 2001 | 04:05 AM
black019's Avatar
i wannt see pics of yalls hoods!
Old Nov 25, 2001 | 08:50 AM
RedMax95's Avatar
tilley has pics on onlineshowoff and if we get a group together next sat. i can get pics of maxis
Old Nov 25, 2001 | 11:09 AM
Stillnmax's Avatar
www.geocities.com/stillnmax/maxima.jpg
Old Nov 25, 2001 | 12:15 PM
MAXIPADMAN's Avatar
hmmm... that doesnt look like carbon fiber to me. Was it painted white? The only thing i see that would make you think it is MAYBE carbon fiber is that there are no window washer sprayers on it. Personally, i like the woven carbon fiber look.
Old Nov 25, 2001 | 12:31 PM
RedMax95's Avatar
which as i mentioned before only looks right on a black car
Old Nov 25, 2001 | 12:34 PM
MAXIPADMAN's Avatar
i dunno.. my max is dark green, and i think it looks ok on my car. Thats just my opinion tho.
Old Nov 25, 2001 | 01:36 PM
RedMax95's Avatar
oh really, well excuse me, it looked good on your car, i thought it was black, oh well, it only looks right on really dark colors then
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
