Navigation input while in motion
Old Jun 4, 2009 | 08:02 PM
Kevin's Avatar
Anyone know how to disable the motion lockout in the OEM NAV system? Is it a switch in the VSS line ? Or do I have to find and ground the brake signal ?
Kevin
Old Jun 4, 2009 | 11:42 PM
a33i30's Avatar
I have been trying to figure out the same thing for my m35.
Old Jun 5, 2009 | 08:44 AM
MetaOrbit's Avatar
Got Projectors?
I would imagine a toggle switch on a VSS wire going into the unit would accomplish what you're looking to do.
Old Jun 5, 2009 | 05:25 PM
Kevin's Avatar
going to give it a shot, I have the switch and the wiring. Question - anyone know which wire from the back of the NAV harness is the VSS line?
Old Jun 5, 2009 | 08:57 PM
MetaOrbit's Avatar
Got Projectors?
Originally Posted by Kevin
I'd take a look at the FSM and see if there's a wiring diagram. I'd look but I don't have a copy on this computer.
Old Jun 6, 2009 | 06:24 AM
ZGadson's Avatar
Infiniti Navigation Bypass Module
Old Jun 9, 2009 | 03:34 PM
pmohr's Avatar
No more Maximas...
Originally Posted by ZGadson
Check the compatibility list, it may very well not work. Chances are just that he's not tested it, though.
VSS line is pin 14 on the back of the nav control unit, purple/red wire.
Note that the navi may use the GPS in addition to VSS at normal travel speeds, the FSM doesn't really clarify which speed input it uses to lock out the screen.
Old Jun 9, 2009 | 07:27 PM
Kevin's Avatar
Thanks Pmohr,
Will have to try this out this weekend and report what happens. IF it works like my other car it should give the passenger a set period of time to enter the destination before you have to re-trip the switch. I will probably mount a switch in the ashtray or something.
Old Jun 11, 2009 | 05:24 PM
samabhi124's Avatar
Yeah! It is a toggle switch over the VSS line.
Old Jun 11, 2009 | 10:08 PM
Kevin's Avatar
Just did the hack, will post some pics in a new post. Thanks again pmohr for helping me ID the VSS line.
Old Jul 3, 2009 | 01:23 PM
HomerMAC's Avatar
Donating i30 Owner
the OEM system uses the VSS line in slow trafic to update your point on the map. the GPS is used once you get moving.. like on a highway... so if VSS not connected then your car on the map will be off..
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
