why does my car hate me
Old Nov 26, 2001 | 06:55 PM
madmax26
last week my car lost its idle point. i have a 95 SE 5 speed with 60 k miles. when the clutch goes down and the tach is supposed to drop to like 600-800 rpm range, it went straight to zero and just stalled, car drove perfectly fine, only thing messed up is the idle. First tried dry gas for water in the tank. next tightened throttle wire and raised idle screw about 1 mm and now it idles right where it used to about 700 rpms. i did that temporary fix. when ur car is cold it will usually idle at 1300-1500 rpms and gradually drops as the car warms up. my car will now only idle at where i set it, and wont go up or down, it struggles a lil bit when its cold too becuz its supposed to be up, but after car warms up its right where i set it. We changed the coolant sensor today, and it didnt do anything, what is the next step, what controls whether it will idle higher or lower depending on the temperature, thanks. tried search, cant seem to find an answer
Old Nov 26, 2001 | 07:27 PM
Maury's Avatar
clean your idle air control valve - so a search on iacv. good luck
Old Nov 26, 2001 | 07:28 PM
KWheelzSB's Avatar
Re: why does my car hate me
Are you currently getting a check engine light in conjunction with the described behavior?
Did you pull a code from the ECU that told you to replace the coolant temp. sensor?
Old Nov 27, 2001 | 02:45 AM
puremax's Avatar
Re: Re: why does my car hate me
You probably didn't give that Max what it wanted bay area thug boy. U gotta feed a dog when it's hungry ****.>?":")(_)_ 101 liven' up the life.
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
Balkins
Aug 12, 2015 06:39 AM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
