OEM keyless remote isnt working
Old Jul 25, 2009 | 06:08 PM
wish2345's Avatar
i got an OEM remote from some one off this site but i cannot get it to sink up with my car as a second keyless remote. I have followed the steps but isnt working. Has any one added a second remote with no issues ?
Old Jul 25, 2009 | 06:58 PM
foodmanry's Avatar
Da Roller Coaster!
Yes, perhaps you need to clear it first? Maybe remove the battery. There might be a way to clear it and then sync.
Old Jul 26, 2009 | 12:13 AM
DennisMik's Avatar
compare the fcc id number on the back of the two key fobs. the new one has to be the same as your original if it is the correct one.
taking the battery out of a key fob is the closest thing to resetting a key fob.
Old Jul 26, 2009 | 12:20 AM
DennisMik's Avatar
as i read the original post again, a question. You said the new remote does nor work as the second. Does it work as the first? If it does, does your original remote work as the second? If the answer to 'does it work as the first" is yes, then you have a programming proceedural problem.
Old Jul 26, 2009 | 08:18 AM
ridinwitha35's Avatar
Are you programming both remotes at the same time and you just can't get the second one to "work"?
If that's the case, I would try programming each individually and rule out a bad/faulty/low-battery/wrong remote.
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
kenc15
Aug 5, 2015 08:29 AM
