VQ35 Pathfinder Engine Parts
Old Aug 4, 2009 | 08:50 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
'02 VQ35 Pathfinder Engine Parts & Intake Manifold
Got a disassembled '02 VQ35 Pathfinder engine that im in need of getting rid of. I have most of the major engine parts available for sale.
I have the cylinder heads, timing covers, chains, sprokets, upper, middle, and lower intake manifold as well. The only things that are not for sale are the throttle body and engine block.
Also have the crank, piston, and rods available for anyone that wants to try to make a VQ33 stroker.
Don't know what the pricing should be, but buyer pays shipping. Local pickup get first dibs as well.
Old Sep 6, 2009 | 05:35 PM
KRRZ350's Avatar
Free bump.........
Old Sep 19, 2009 | 11:06 AM
nismology's Avatar
Interested in the heads. Perhaps the covers and intake sprockets as well. Price?
Old Sep 19, 2009 | 01:49 PM
I have the VTCs that came with the heads. I thought about intergrating the Pathy VTCs to a VQ30 application but you have to use the VQ35 pathy heads or do some crazy machine work to the VQ30 heads.
Anyways I will part with everything you listed for $200 + shipping.
Old Sep 21, 2009 | 04:29 PM
nismology's Avatar
Well I planned on using Pathy heads on a 3.5 block so that's no issue. The only thing that really worries me about all this is the mods needed to be made to the outer cover to accomodate the belt tensioner and the power steering bracket on the inner cover. And from looking at the pathy heads they don't have VTC solenoids on them. Is it an on/off type of thing VE style or PWM like the 3rd gen motors?
And the pathy heads must have the same combustion chamber CC as 3.0's since they both have flat top pistons and 10:1 compression (unless the deck clearance is different, which I doubt). Why couldn't you use them on your 3.0 block?
With that said I think I'm gonna scrap the VTC idea lol. I think I can reach my goal without it. How much for just the heads?
Old Sep 21, 2009 | 06:25 PM
Yeah if you want to run the VTCs you will need the pathy heads, VTC solenoid bearing caps, valve covers (maybe I think VQ35 maxima ones would work), and timing covers. This was the 2nd problem for this swap getting the PS and other ancilleries to work with whacky timing covers. I may still do this with a VQ30 in the future but highly unlikely. My methods have changed to a more simple way of doing things to keep reliability instead of being the "first" to do something on a Maxima.
I believe these solenoids are PWM they look very similar to VQ35 Maxima ones.
Pathy pistons are flat top, but VQ30 ones have a slight dish. Both blocks have their pistons at zero deck clearance. So im not sure on the exact combustion chamber volume.
I don't see a need to run the Pathy heads on a VQ30 block, my build is going to be all VQ30.
If you still want the heads I will do $100 + shipping. You will need the bearing caps, but do you need the VTC solenoids or will you make cover plates for them?
Old Sep 21, 2009 | 08:29 PM
nismology's Avatar
@ the VQ30 piston dish. You have any up-close pictures of one? All the ones I've seen are from pretty far back. I really wish I knew the PF heads' chamber volume so I can determine the resulting C/R using Gen II 3.5 pistons.
Sounds good. I'll let you know when I can pull the trigger. In the next few days hopefully. I wonder if VQ30 cam caps are compatible with these heads...hmmmm
Edit: What's the condition of the motor in general like? Any oil starvation issues? Anything approaching the wear limit? I know I'm just getting the heads but wondering if the cam bearing surfaces and bucket shims are ok.
Old Sep 22, 2009 | 06:35 PM
Yeah I will dig up a VQ30 piston sometime and post a photo. It has a very slight dish from what I remember.
I would highly recomend you run these cam caps. When the heads are machined the caps are bolted to the heads and then they are drilled for the cams. Nissan VQs are very tight tolerance but that is why they don't sell the cam caps as individual parts, they only work for the heads they are machined with.
I checked out the heads they definitely need a clean up. Don't think the motor was in the best shape there is a bit of sludge build up. There is some wear but I dont think its unusual for an engine of this mileage. Anyways let me know.
Old Sep 22, 2009 | 08:00 PM
nismology's Avatar
True, dunno how that slipped my mind. Same deal with main caps.
What was the mileage anyhow?
Old Sep 23, 2009 | 06:31 AM
tht98maxkid's Avatar
im interested in the cams... how much for them
Old Sep 23, 2009 | 06:03 PM
100K I think. I will pull off the cams and check it out in better detail sometime this weekend.
Old Sep 23, 2009 | 06:04 PM
The cams have some surface rust on them from being exposed to air for so long. If you still are interested I will sell them for $50 + shipping.
Old Oct 3, 2009 | 09:03 AM
DAVE Sz's Avatar
Hooooooonda.....
Can you snap a picture of the bottom side ports of the lower IM?
Old Oct 7, 2009 | 07:42 PM
The intake manifold lower looks just like a DEK lower, swirl valves and all. Do you mean the Pathy upper or middle intake manifold?
Old Oct 8, 2009 | 02:56 PM
DAVE Sz's Avatar
Hooooooonda.....
I meant the lower. I read that the lower ports on that are the same as a 3.5 but the upper are the same as the 00VI.
Old Oct 8, 2009 | 04:03 PM
MOHFpro90's Avatar
Price of one of the upper manifold shipped to 32119?
Old Oct 17, 2009 | 05:58 AM
Lower ports look like DE/DEK ports. The heads have DE/DEK style intake ports.
Old Oct 17, 2009 | 06:02 AM
Oppps missed this post. Check your PM box.
Old Oct 21, 2009 | 06:24 PM
tyler5619's Avatar
mmm, stroker. lol...
how much for the crank, piston, rods, cams?
halfpol
Oct 17, 2022 12:16 PM
Matt93SE
Apr 8, 2018 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
