Ebay Wheel Spacers
Old Aug 19, 2009 | 02:31 PM
anomaly117's Avatar
Ebay Wheel Spacers
http://cgi.ebay.com/ebaymotors/PAIR-...Q5fAccessories
anyone know anything about these? good idea? bad idea? i just want my rear wheels to kick out a little further.
Old Aug 19, 2009 | 03:34 PM
BLACKonBLACK98's Avatar
Former Vendor
"molded" aluminum
Old Aug 19, 2009 | 04:18 PM
OOmaxSE's Avatar
Must be "hubcentric." If you're looking at anything above ~5mm spacers, you should see the lip to center the wheel otherwise it's trouble because the hub only sticks so far out to fit the wheel. Don't go cheap on these parts.
Old Aug 19, 2009 | 06:45 PM
PulsarGTS's Avatar
Bought those at pepboys and took them back the same day. Don't want.
Old Aug 19, 2009 | 07:27 PM
a33i30's Avatar
The bad part is that you need longer studs, I want 20mm for my backs but it's damn pricey with the studs.
Old Aug 19, 2009 | 07:43 PM
anomaly117's Avatar
Originally Posted by BLACKonBLACK98
"molded" aluminum
wow i didnt even catch that.
everyone else, your opinions have opened up enough more than potential cons to turn me off. imma save my money for somethin better.
Old Aug 20, 2009 | 02:37 AM
vastmax's Avatar
not as expensive as you think...
http://cgi.ebay.com/ebaymotors/20MM-...Q5fAccessories
this guy has some great feedback too...
Old Aug 20, 2009 | 11:37 AM
anomaly117's Avatar
i saw those, but i think 20mm is a lot more than i want/need
Old Aug 20, 2009 | 12:31 PM
Former Vendor
just to sum it all up, you should be looking for:
  • machined aluminum. no cast, no steel.
  • hub-centric at the least. wheel-centric is awesome but you'll only get it with rings or custom made spacers.
  • extended studs if you need more than 3mm.
  • sticking to the name brands makes life easy.
Old Aug 20, 2009 | 01:03 PM
vastmax's Avatar
he also makes 15mm with the studs pressed in... anything smaller and you'll have to replace your oem studs
Old Aug 20, 2009 | 01:16 PM
anomaly117's Avatar
anyone know where i can find before/after pics of spacers? i just dont wanna go too big.
Old Aug 20, 2009 | 02:18 PM
Gollum67's Avatar
Not exactly a maxima but it will look something like this. I say get the H&R spacers forget those no name brand "washers"
Old Aug 20, 2009 | 04:12 PM
anomaly117's Avatar
yea i already saw that on the page, i wanted to see the diff between something like 15mm spacers.
Old Aug 20, 2009 | 05:03 PM
Former Vendor
check the member's rides.
on stock wheels you can't find a reputable "too big" spacer (largest reputable manufacturers make is 30mm).
Old Aug 20, 2009 | 05:15 PM
anomaly117's Avatar
ok, so my car is sitting on H&R sports, rear is 1.4" drop. the wheels are just tucked under the fender more than id want. im only gonna put spacers on the rear wheels.
that being said, would 15mm be too much if im not doing the front? will it look hokey?
Old Aug 20, 2009 | 05:38 PM
Gollum67's Avatar
Check this thread out:
http://forums.maxima.org/advanced-su...l-spacers.html
Old Aug 20, 2009 | 05:40 PM
anomaly117's Avatar
thx
Old Aug 20, 2009 | 06:01 PM
Former Vendor
15mm should be just about right to get an even stance front and rear. i know 4g better but it's similar.
Old Aug 20, 2009 | 06:11 PM
anomaly117's Avatar
cool, thanks alot. might even do 20mm then.
Old Aug 20, 2009 | 07:39 PM
vastmax's Avatar
here's a nice tool so you figure out exactly the spacers you need...
http://forums.maxima.org/tires-wheel...-will-fit.html
Old Aug 20, 2009 | 07:59 PM
anomaly117's Avatar
the inch to mm conversion was very helpful and good to know, thanks. other than that i have an idea of what's what, but that certainly is an impressive and helpful write-up
Old May 5, 2010 | 06:25 AM
seanreid7's Avatar
15mm in the rear alone will be okay. This is a great setup!! I'm actually going after the same setup. My wheels are 18x8 all the way arround and when I lowered my max, it seemed to be tucked in the rear a little more than I wanted. 15mm spacers will do me some justice for the rear and safe from hitting or sratching the fenders. I don't recommend anything over 15mm though.
Old May 5, 2010 | 07:40 AM
NmexMAX's Avatar
dot dot dot ...
pretty sure he found what he needed ... old post FTL.
Old May 5, 2010 | 09:06 AM
anomaly117's Avatar
yea you dug up quit the fossil
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
