Car will not get off from floor...
I was getting a clunking noise and narrowed it down to the sway bar end link.
Problem now is that the side with the snapped end link will not get off the ground.
Jacking from the center front jack point the passenger side is able to clear the ground and I can place jack stands, but the driver side... not so much, the tire is still on the ground. I am also on a even driveway.
So, two options at the moment:
1) Work without a jackstand and chance it with the hydraulic jack.
2) Try to get a jackstand on the front jack point under the engine.
3) Anything else you guys can think of?
Thanks,
Oh, and attached pic for your viewing pleasure.
Broken sway bar link
Looks like the darn thing just snapped in two
Thanks,
Thanks for the suggestions.
My scissor jack was damaged and thrown out, but if needed, I will use the jack to jack the control arm if needed and when I get the car off the ground
I might just have to find something to put the jack on and jack up the car front with a extra inch or two to see if it's enough.
As for jacking up one side at a time, that would be possible as the option 1, however I would just be risking the jack failing at a crucial moment while my hands are in the wheel well area.
I never said anything about working on the car supported by only a floor jack.
But yah, I just ended up placing a concrete slab under the jack and got the car high enough.
The nuts were on really tight though, had to use a 24" breaker bar to get it off, but all done and no more clunking noise
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
