Looking for new OEM pedals
Old Aug 29, 2009 | 10:07 PM
PatKeo6373's Avatar
So my brake and clutch pedals on my 02 have see better days and i want to replace them. I really dont want those crappy pedals everyone puts on top of the stocks. I want to replace them with OEM pedals but i can find them anywhere. Does anyone know where i can find OEM aluminum pedals
Old Aug 29, 2009 | 10:53 PM
CMax03's Avatar
Get the crossdrilled ones from Nismo or Courtesy Nissan they slip over just like the Oem rubber pedal covers do. I've had mine 9 yrs now, in my 2000 and now In the 2003 along with the modified dead pedal. These aren't screwed to the pedal like that cheap a$$ ****...they slip onto the actual pedal and never ever seem to wear down!
Old Aug 30, 2009 | 09:54 AM
PatKeo6373's Avatar
are these the OEM drilled aluminum pedals? my pedals look like the 350z pedals
Old Aug 30, 2009 | 10:02 AM
CMax03's Avatar
It's for 350Z but fit all Nissans...It's not screwed on it fits on like the regular rubber pads, with an aluminum face and the holes have a plastic/ hard rubber grip stud that prevents your foot from slipping.... I've had mine for 9 yrs no problems!
http://www.courtesyparts.com/nissan-...h=714_881_1238&
Old Aug 30, 2009 | 10:34 AM
PatKeo6373's Avatar
sick ordering them now thanks for the info
Old Aug 30, 2009 | 10:42 AM
CMax03's Avatar
Search thru the Courtesy site there's a gas pedal, dead pedal, clutch, M/t brake and A/t brake pedals available best quality aftermarket I've ever bought!
Old Aug 30, 2009 | 11:08 AM
Rochester's Avatar
CMax, I don't see the studs you're referring to. The holes look recessed, not raised. Here's the Courtesy Image:
So are you sure about that?
Also (and this is probably a redundant question for the org), are these the pedal covers that come with the HLSD 6MT? I don't have the LSD. So sad.
Old Aug 30, 2009 | 12:24 PM
Unklejoe's Avatar
Those are the pedals that I have.
I also have a HLSD. (2002 SE)
Old Aug 30, 2009 | 01:22 PM
HotshotVQ35's Avatar
sure looks like mine
Old Aug 30, 2009 | 02:45 PM
Rochester's Avatar
"studs", hotshot?
I've never seen these up close except in these pictures, and I don't see the studs cmax is referring to.
Old Aug 30, 2009 | 02:46 PM
i'll snap a shot of mine and postem up
"studs", hotshot?
Old Aug 30, 2009 | 03:18 PM
djfrestyl's Avatar
Suspension Yoda
They're raised. The plastic/rubber comes up slightly through the holes. On the brake and clutch only though. On the gas pedal they're just empty holes.
edit: I believe these pedals are also found on the AE 2001 Maxima.
Old Aug 30, 2009 | 03:26 PM
Rochester's Avatar
Thanks for the details, DJ.
Nice! Looking forward to the pics.
I've been looking for an inexpensive thing to do with the car while I'm backordered on spacers.
Old Aug 31, 2009 | 12:21 AM
CMax03's Avatar
You can't see how the plastic comes thru the holes and acts as an anti-slip, I will have too take a side profile of my pedals.
Old Aug 31, 2009 | 02:26 AM
FlipCpt45's Avatar
yep.. mine are raised... they're pretty worn down though..
Old Aug 31, 2009 | 10:22 AM
not sure if this helps or not..
Old Aug 31, 2009 | 10:32 AM
Rochester's Avatar
not sure if this helps or not...
Well, I'm not the OP, but this is certainly a welcome bit of information for me.
I like it. And now I want it. Hmm... where'd I put that upgrades list...?
Thanks, Hotshot. Very decent of you to take that photo.
Old Aug 31, 2009 | 10:49 AM
not a problem
Old Aug 31, 2009 | 05:09 PM
CMax03's Avatar
Good shot...HotShot!!! You beat me too it!
Old Aug 31, 2009 | 08:13 PM
PatKeo6373's Avatar
these pedals are the exact pedals that come on the 5.5 gen just listed for 350z but its the same part # for the maxima and 350z
Old Sep 1, 2009 | 01:21 PM
Amitch's Avatar
I'm definitely grabbing a set of these!
Old Oct 18, 2009 | 06:52 AM
Rochester's Avatar
Thanks for that link, CMax03. I have a pair of these brake/clutch pedal pads arriving this week from Courtesy.
But what about that accelerator pedal? That looks more like a replacement part than a slip-on.
Old Oct 18, 2009 | 07:08 AM
nismowolfe's Avatar
They have just the gas pedal pad search your year max and then search pedals in second window. I too want these how do they attach. I have a 02 max auto and want the brake and gas pedal can I buy these parts and just snap them on
http://www.courtesyparts.com/46531-p...ml?cPath=1956&
http://www.courtesyparts.com/18110f-...ml?cPath=1956&
Old Oct 18, 2009 | 07:33 AM
Rochester's Avatar
That first link appears to the same pedal used in the 5.5 HLSD Maxima. Thanks for finding that, nismowolfe!
Has anyone replaced this accelerator pedal and have any comments on the installation?
Old Oct 18, 2009 | 08:03 AM
nismowolfe's Avatar
No problem hopefully someone can shed some light on the gas pedal. It would be nice if this would just snap on or something instead of buying the whole pedal assembly.
Old Oct 18, 2009 | 08:10 AM
looking at the pic i took and the pic in the link, looks to me like it should just snap right on
Old Oct 18, 2009 | 11:42 AM
djfrestyl's Avatar
Suspension Yoda
The gas pedal is a replacement part. It does not just snap in. It's the entire accelerator assembly. Installation is equally as easy as the brake/clutch. Few nuts, disconnect the cable, then reinstall the new one. The brake and clutch are a pain because you really have to pry them on/off.
Old Oct 18, 2009 | 11:55 AM
nismowolfe's Avatar
Just to confirm, they do sell both the pedal and the whole assembly, so I could not just buy the pedal and put it on my existing pedal assembly correct? There is a difference between the two pedal assemblies?
Old Oct 18, 2009 | 04:33 PM
djfrestyl's Avatar
Suspension Yoda
I've never seen JUST the pedal...post a link.
Old Oct 18, 2009 | 05:26 PM
nismowolfe's Avatar
I did post #23 ones a brake pedal the other one is a gas pedal
Old Oct 18, 2009 | 05:55 PM
Rochester's Avatar
Well, it sure looks like Courtesy is just selling the pedal, without the rest of the accelerator assembly.
Old Oct 18, 2009 | 06:12 PM
djfrestyl's Avatar
Suspension Yoda
Cool, looks like they are. Makes things easier and cheaper.
They weren't selling them alone 6 years ago when I bought em
Old Oct 18, 2009 | 06:50 PM
Rochester's Avatar
Did you swap it out for looks, or feel?
I'm thinking with your suspension installs and all, you get access to lots of Maximas. Do you have any impressions on the aluminum pad vs. the rubber one?
Old Oct 18, 2009 | 07:09 PM
djfrestyl's Avatar
Suspension Yoda
I did it all for looks.
Ya, I do
Not really - I drive an autotragic.
Old Oct 18, 2009 | 07:29 PM
Rochester's Avatar
Does anyone have any impressions on the aluminum accelerator pad vs. the rubber one?
Appearance aside, I'm more interested in feel. I mean, if I don't like the way these clutch & brake pads feel underfoot, I'm putting the rubber ones right back on, no matter how good the aluminum shod ones look. You know what I mean?
Priorities, man... functionality, form, bling. In that order.
Old Oct 18, 2009 | 07:30 PM
djfrestyl's Avatar
Suspension Yoda
I suppose. I didn't feel a difference between the two. The brake pedal still has rubber pads on them to prevent slippage.
Old Oct 18, 2009 | 07:40 PM
Rochester's Avatar
Yes, they do, but instead of a grooved, rubber surface, they're rubber nubs. (Good God, I just wrote the words "rubber nubs".) I'm assuming improved grip with the nub design (again with the nubs), than you would with the other pads.
Conversely, I'm assuming the all-aluminum surface on this accelerator pad would be a more sensitive feel than the grooved rubber surface of the non-HLSD pad. Here you don't want confident force (like the brake or clutch), instead you want finesse.
You might think I'm over-analyzing this crap too much, but I refuse to think the design motivation for "sport" pedals was appearance over function.
Old Oct 18, 2009 | 07:45 PM
djfrestyl's Avatar
Suspension Yoda
I do, but I hear ya, makes sense.
Old Oct 18, 2009 | 07:51 PM
Rochester's Avatar
It's all theoretical for me at the moment.
I'll post something more empirical after I get the brake & clutch pads.
Old Oct 20, 2009 | 04:31 PM
Rochester's Avatar
The brake and clutch pedal pads showed up tonight from Courtesy Nissan.
Taking the old ones off was simple; requiring only a little force on one corner, then twist and slip off. However, putting the new ones on was not easy. After struggling for a few minutes, I tried using a small flathead screwdriver to help. And although it did help, it didn't do the trick. You can see from the picture below of the backside how thick the rubber is.
Finally, I applied a little WD-40 to the pad. Starting from the top, I worked the top 2 corners on. Then, to get the bottom of the pad over the pedal, you just have to be steady and firm, slowly pushing to the edges from the front of the pad. It's like you're giving the pedal a seriously strong massage, and after a while it will fully seat.
I know that sounds dumb, but it's apt.
I haven't driven with them yet, but damn... they look good!
