Looking for new OEM pedals
So my brake and clutch pedals on my 02 have see better days and i want to replace them. I really dont want those crappy pedals everyone puts on top of the stocks. I want to replace them with OEM pedals but i can find them anywhere. Does anyone know where i can find OEM aluminum pedals
http://www.courtesyparts.com/nissan-...h=714_881_1238&
It's for 350Z but fit all Nissans...It's not screwed on it fits on like the regular rubber pads, with an aluminum face and the holes have a plastic/ hard rubber grip stud that prevents your foot from slipping.... I've had mine for 9 yrs no problems!
So are you sure about that?
Also (and this is probably a redundant question for the org), are these the pedal covers that come with the HLSD 6MT? I don't have the LSD. So sad.
CMax, I don't see the studs you're referring to. The holes look recessed, not raised. Here's the Courtesy Image:
I also have a HLSD. (2002 SE)
They're raised. The plastic/rubber comes up slightly through the holes. On the brake and clutch only though. On the gas pedal they're just empty holes.
edit: I believe these pedals are also found on the AE 2001 Maxima.
Nice! Looking forward to the pics.
I've been looking for an inexpensive thing to do with the car while I'm backordered on spacers.
But what about that accelerator pedal? That looks more like a replacement part than a slip-on.
They have just the gas pedal pad search your year max and then search pedals in second window. I too want these how do they attach. I have a 02 max auto and want the brake and gas pedal can I buy these parts and just snap them on
http://www.courtesyparts.com/46531-p...ml?cPath=1956&
http://www.courtesyparts.com/18110f-...ml?cPath=1956&
Has anyone replaced this accelerator pedal and have any comments on the installation?
The gas pedal is a replacement part. It does not just snap in. It's the entire accelerator assembly. Installation is equally as easy as the brake/clutch. Few nuts, disconnect the cable, then reinstall the new one. The brake and clutch are a pain because you really have to pry them on/off.
Just to confirm, they do sell both the pedal and the whole assembly, so I could not just buy the pedal and put it on my existing pedal assembly correct? There is a difference between the two pedal assemblies?
I'm thinking with your suspension installs and all, you get access to lots of Maximas. Do you have any impressions on the aluminum pad vs. the rubber one?
Does anyone have any impressions on the aluminum accelerator pad vs. the rubber one?
Appearance aside, I'm more interested in feel. I mean, if I don't like the way these clutch & brake pads feel underfoot, I'm putting the rubber ones right back on, no matter how good the aluminum shod ones look. You know what I mean?
Priorities, man... functionality, form, bling. In that order.
Conversely, I'm assuming the all-aluminum surface on this accelerator pad would be a more sensitive feel than the grooved rubber surface of the non-HLSD pad. Here you don't want confident force (like the brake or clutch), instead you want finesse.
You might think I'm over-analyzing this crap too much, but I refuse to think the design motivation for "sport" pedals was appearance over function.
The brake and clutch pedal pads showed up tonight from Courtesy Nissan.
Taking the old ones off was simple; requiring only a little force on one corner, then twist and slip off. However, putting the new ones on was not easy. After struggling for a few minutes, I tried using a small flathead screwdriver to help. And although it did help, it didn't do the trick. You can see from the picture below of the backside how thick the rubber is.
Finally, I applied a little WD-40 to the pad. Starting from the top, I worked the top 2 corners on. Then, to get the bottom of the pad over the pedal, you just have to be steady and firm, slowly pushing to the edges from the front of the pad. It's like you're giving the pedal a seriously strong massage, and after a while it will fully seat.
I know that sounds dumb, but it's apt.
I haven't driven with them yet, but damn... they look good!
