has anyone changed front wheel bearings?
Old Nov 29, 2001 | 07:46 AM
nismo2020's Avatar
Needs non-Maxima Friends
my left side is bad. the nissan dealer quoted me $289 to do it. i have done it before in high school but that was a long time ago. also how much for the parts ?
Old Nov 29, 2001 | 07:49 AM
Sonic's Avatar
MaxVQ did this a few days ago. His website with instructions is http://www.motorvate.ca
Old Nov 29, 2001 | 07:54 AM
njmaxseltd's Avatar
http://forums.maxima.org/showthread.php?threadid=80784
Old Nov 29, 2001 | 08:03 AM
nismo2020's Avatar
thanx
thanx - i cant get his website to pull up but i got the p/n for the bearing and seal.i should be able to figure it out from there. wierd how another max owner is going thourgh the same problems as me.
Old Nov 29, 2001 | 09:07 PM
MaxVQ's Avatar
Re: thanx
Why could you not get to my web site? Did you try and it was down?
Please let me know....
Old Nov 29, 2001 | 10:41 PM
Weasel's Avatar
Re: thanx
I'm having the same problem, except I think both of mine are bad. That price is a little high also, I got a quote of $150 with parts for each side.
Old Nov 29, 2001 | 11:13 PM
black019's Avatar
Re: thanx
dont worry im havin that problem too
Old Nov 29, 2001 | 11:49 PM
NYCe MaXiMa's Avatar
What exactly are the signs of a bad wheel bearing? I question some of the noises coming from the front suspension sometimes...
thanks
Old Nov 30, 2001 | 12:13 AM
Weasel's Avatar
thanks
You'll hear a pulsing humming or growling noise from the front of the car when you're turning at speed, usually above 30mph (at least for mine). Sadly, I don't think there's any concrete test for it other than making sure the noise isn't coming from anywhere else. You just can't inspect them without taking the hub assembly apart.
Old Nov 30, 2001 | 03:46 AM
Rensis19's Avatar
Re: has anyone changed front wheel bearings?
$289 seems pricey. I ordered the part for $60 from the nissan dealer in Arizona (in the links page) and had it installed for $90. I am in Germany so I had a local garage do it.
Old Nov 30, 2001 | 04:38 AM
nismo2020's Avatar
i have the exact same symptoms as Weasl and MaxVQ i will try again and let you know. today wheni drove the car to work the noise got even worse now its making a clanking noise every fourth whoop whoop. taking it nissan in about thirty mins. cant afford to wait any longer.
Old Nov 30, 2001 | 05:55 AM
AndyXXL's Avatar
thanks
When my right wheel bearing went bad I heard a *tum tum tum* noise while making a right turn. My steering wheel was shaking too.
Old Nov 30, 2001 | 06:11 AM
Weasel's Avatar
The noise everyone has posted in here is the classic symptom of bearing failure... I can't really see how it would cause a clanking noise without seriously affecting driveability of the car, I think that noise at least points to something else.
Old Nov 30, 2001 | 06:39 AM
190hpKiLLA's Avatar
Granny Driven
I replaced front left baring without a hub(make sure your hub is in good condition in the front. If not replace it also). It cost me 120.
And I also replaced rear right(that came with a hub). That cost me about 120 too. Labor included.
Old Nov 30, 2001 | 06:59 AM
nismo2020's Avatar
Re: Re: thanx
still cant get it to pull up ?
Old Nov 30, 2001 | 07:21 AM
Weasel's Avatar
Re: Re: Re: thanx
Works for me...
Old Nov 30, 2001 | 07:24 AM
nismo2020's Avatar
Re: Re: Re: Re: thanx
Originally posted by Weasel
Works for me...
must be my slow a$$ computer.
Old Nov 30, 2001 | 07:48 AM
Wizeguy's Avatar
Re: Re: Re: thanx
Viagra! Not that I'd know... :P
Old Nov 30, 2001 | 04:22 PM
tom_98se's Avatar
How to check for sure
Jack up the front of the car so the offending wheel is hanging. Then put your hands on the top and bottom of the wheel. Pull back and forth on the top and bottom of the wheel to check for looseness. If the top or bottom of the wheel deflects even a little bit, odds are you have a failing wheel bearing.
BTW I had a quote of about $300 once from a local garage to do a wheel bearing. He had me by my b*lls though since the car was nearly undrivable. Nice to know the parts involved aren't too expensive; I'll do it myself the next time it happens.
Regards,
TOM
Old Nov 30, 2001 | 05:57 PM
Weasel's Avatar
Re: How to check for sure
Regards,
TOM
Do I try to make the wheel move along its axis of travel or perpendicular to it?
Old Dec 1, 2001 | 02:56 AM
nismo2020's Avatar
that would probably explain why after i got my wheels balanced the car still wobbled and shakes on the freeway. i did not have a chance to take my car to the dealer but it will be done next week.
Old Dec 1, 2001 | 08:37 PM
MaxDriver98's Avatar
My car has the same problem when I turn right it makes a humming sound. What if I don't get it fix? What will happen?? Front Wheel Bearing Replacement.
Old Dec 4, 2001 | 02:54 AM
KWheelzSB's Avatar
Re: Re: How to check for sure
I'm gonna go with "perpendicular to,"
in other words, eg: you're pushing on the outer sidewall at the bottom of the tire and pulling on the inner sidewall at the top of the tire with the vehicle securely raised either on a lift or on jackstands. Use a strong back and forth pressure to feel for any "play." There should be none.
Do not trust a jack alone for this test.
Old Dec 4, 2001 | 05:19 AM
Lime's Avatar
SEARCH IS YOUR FRIEND!!!!!!
Old Dec 4, 2001 | 07:14 AM
KiLIAkLoWn's Avatar
Had Hub Bearing Changed
I had my driver's side hub bearing go bad. Everyone want 200+ to do it. I took it to tire kingdom and paid i think some where around 120. The part was about 40 bucks. Hopefully no more go bad!!
Old Dec 5, 2001 | 06:48 AM
Curt Deiner's Avatar
Re: Had Hub Bearing Changed
My left front bearing is going bad too. Nissan dealer replaced it about 11K miles ago when they replaced the bearings in my 5spd tranny. They are already talking hub replacement as well. I think they should have replaced it before. We'll see.
It was easy to recognize with the wheel off the ground, like been said, grab the top and bottom of the wheel and wiggle. The wheel should have no play.
Old Dec 5, 2001 | 09:19 AM
nismo2020's Avatar
worst case its freezes up and wont turn.
Old Dec 5, 2001 | 10:03 AM
dwapenyi's Avatar
The symptoms of a bad wheel bearing also happen to be very similar to symptoms of a bad tire, wheel, or wheel balance. Before concluding that your wheel bearing is bad, and hterefore a more expensive repair, try rotating your tires. If those humms, growls etc move with the rotation, then you wheel bearings are OK
DW
Old Dec 5, 2001 | 11:35 AM
Weasel's Avatar
FYI, if you want a great deal on the parts for this repair (bearings and seals) call Dave B at Town North Nissan. His number is in the 5th gen stcicky about parts. He'll get you OEM parts at prices that compare very well to the ones someone got at Tire Kingdom. I don't want to post exact prices because some people don't like doing that, but Dave will get you a great deal, and great post-sale service.
Old Dec 5, 2001 | 05:03 PM
Briguy1971's Avatar
Interesting thread.. Here is a question.
I have been hearing noises from what seems to be my right front wheel. It makes a humming noise that increases when I turn to the right. It actually makes a thump-thump-thump kinda noise when turing a corner. (Don't you just LOVE noise descriptions?) Anyway - my dad and I got together and rotated the tires - did the push-pull test to see if there was any play and there wasn't. We even ran the car up on blocks to see if we could locate the noise. We couldn't really hear anything with the wheels off. My dad says that he thinks its the CV joints. My dad is pretty mechanical but I don't want to spend the money on a rebuilt axle (cheaper than just the CV joint) is it's someother problem... Any ideas?
Brian
Old Dec 5, 2001 | 09:25 PM
Weasel's Avatar
Brian
If you're going to do the CV joints just buy the wheel bearings anyway. The parts are relatively cheap.
Old Dec 6, 2001 | 12:18 AM
JDM4LIFE's Avatar
where are you people getting these prices? not that i'm saying you're liars, lol, but considering that the front wheel bearings are a sealed unit, those kind always run significantly more than that. right??
Old Dec 6, 2001 | 12:34 AM
Weasel's Avatar
I said where on the previous page.
Old Dec 21, 2001 | 10:17 AM
dwapenyi's Avatar
I just rotated my tires, and the hum I was experiencing stayed right where it was. Damn! My wheel bearing is bad, too.
DW
Old Dec 21, 2001 | 10:35 AM
Weasel's Avatar
I never noticed this the first time... wheel bearings aren't a sealed unit, they're a single part inside the hub assembly that can be replaced on its own. Go to http://www.motorvate.ca for an excellent write-up on replacing wheel bearings.
Old Dec 21, 2001 | 11:08 AM
nismo2020's Avatar
nissan did mine..
hit me up for 289.14 ouch.
Old Dec 21, 2001 | 08:14 PM
Weasel's Avatar
Re: nissan did mine..
For one or two? For two that's not that bad a price.
Old Dec 23, 2001 | 02:48 PM
nismo2020's Avatar
Re: Re: nissan did mine..
right side only. left side was okay.
Old Dec 26, 2001 | 06:38 AM
dwapenyi's Avatar
For those of you who have had the wheel bearing problem, is the hum ALWAYS there, no matter what the speed?? Mine goes away after at >80 mph.
DW
Old Dec 26, 2001 | 06:42 AM
nismo2020's Avatar
DW
mines started at like 10-20 mph and stayed their up to a 100.
