has anyone changed front wheel bearings?
#41
Bummer, didn't want to hear that
Anyway, I'm like 80% sure that my bearing is bad. I'm still hoping that its my tires wearing out, and the agressive tread is making all that noise. My Pirelli P7000s used to do that when they aged. Once I put on a new set, the hum was GONE. I guess I will know for certain when I change to my 15" rims. If the hum is still there, then there's no doubt.
DW
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
DW
Originally posted by nismo2020
mines started at like 10-20 mph and stayed their up to a 100.
#42
Originally posted by dwapenyi
For those of you who have had the wheel bearing problem, is the hum ALWAYS there, no matter what the speed?? Mine goes away after at >80 mph.
DW
DW
#43
Wheel Bearing
Yo, I had the same sound on the drivers side. I just took the car to my regular mechanic (RIPP modifications NYC) and that noise was the axle nut that was loose. If I would of took it anywhere else, they would of charged me $200 for turning a nut.
Check the nut before you pay for nothing!
Maxi-milliyon
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Maxi-milliyon
#44
Re: Wheel Bearing
Hi guys,
Just inspected this thread since I noticed that my Maxima had a hum-hum-hum sound from 15 mph to around 65 mph.
It's at its worst around 25-30mph. However, I have a question for you, how do you know it's the bearing and NOT the hub?
I am thinking of ordering the parts and all, but I don't know whether I should buy the hub and the bearing, or just one of these....
Any lead is appreciated!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#45
Re: Re: Wheel Bearing
Originally posted by ardika
Hi guys,
Hi guys,
#46
I just had the same bearing replaced last friday. . . Cost me $235 for parts and labor. . . As long as you have a press then you should have no problems if you know what you are doing, I didn't and so I paid someone else to do it.
#47
Look at www.motorvate.ca, click on "suspension", and "wheel bearing part 2" to see what it looks like.
Good Luck!
BassAddictJ
08-04-2015 11:38 AM
