relay noise help
Old Sep 14, 2009 | 11:28 AM
jav24's Avatar
relay noise help
i have a maxima 96 and it wont start when i turn the key to on i only get a cliking sound like if the hazardous lights where on, the sound comes from the relays that are located on the passenger side behind the water deposit and i also get the high lights indicator that comes on and off .
Old Sep 14, 2009 | 01:03 PM
urmab's Avatar
I would replace your starter
Old Sep 14, 2009 | 01:30 PM
jav24's Avatar
i found one of the ignition switch 30 fuse that is bad its next to the battery and its a diferent kind of fuse its green and the cover its clear theres 2 more next to it so i replace it with one of the otherones and nothing same problem just the cliking in the relays
Old Sep 14, 2009 | 02:33 PM
Q8BallMAXIMA's Avatar
Did you check your voltage across the battery?
It sounds like you are getting juice to the soleniod for the starter, but the starter doesn't have enough voltage to turn the motor over. I had this problem one time when I left the lights on an drained the battery to the point all of the above mentioned happened.
Luckily I was parked on a slope facing down, popped the clutch to start the car and got the alternator to charge the battery again.
Old Sep 14, 2009 | 02:46 PM
jav24's Avatar
well the battery is 5 months old and i tried the jumstart from the starter and all i get is some spining noise do you think is the starter?
Old Sep 14, 2009 | 02:52 PM
The spinning noise is the starter motor. Your starter solenoid is not engaging the starter motor to the crank. You're better off replacing eveverthing. It would be a PITA trying to rebuild it and you will spend more time than necessary. Starters are anywhere from $120-200...depends on reman or new at an auto parts dealer. Would not recommend a Nissan Stealership, you can get better pricing than that.
Old Sep 14, 2009 | 02:54 PM
jav24's Avatar
can i replace the bushings from the starter im kind of broke right now
Old Sep 14, 2009 | 03:01 PM
If anything, you can try to replace just the solenoid on the starter. The way you describe the problem, it is a soleniod issue. If your starter is spinning fine, I wouldn't mess with the starter bearings. If you can pull a part number off the solenoid, you may be able to x-refence on google or something.
Old Sep 14, 2009 | 03:22 PM
Check this link out.
Napa Auto Parts-Starter Solenoid Switch.
http://www.napaautoparts.com/MasterP...olenoid+Switch
Old Sep 14, 2009 | 03:36 PM
jav24's Avatar
what about the ignition switch 30 a fuse does the selenoid made the fuse blow
Old Sep 14, 2009 | 04:03 PM
If there is a short in the solenoid......yes, because there is not enough resistance inside the coil of the solenoid. A short in the coil is like putting a jumper across battery terminals.... NOT GOOD!!!!!!!!
Was your fuse blown while checking this issue?
Old Sep 14, 2009 | 04:08 PM
jav24's Avatar
no i notice it whille i was cheking the fuses
Old Sep 14, 2009 | 04:18 PM
If it didn't blow the fuse, you may have a case of over resistance or corrosion inside of the solenoid, which is creating a condition which the coil isn't generating the force to push out hard enough to engage the starter gear to the crank.
Check your contact points and be sure they are tight and clear of corrosion...this may cause your solenoid not to engage as well. You may need to remove the air intake box in order to reach those contacts
Remove both the + and - cables from the battery and clean those terminals as well. You will need to remove these anyway before cleaning the contacts. SAFETY FIRST!!!!
Another thing to check is the engine ground cable. Check link:
http://forums.maxima.org/4th-generat...t=ground+cable
Old Sep 19, 2009 | 01:56 PM
jav24's Avatar
i just remove the starter and take it to autozon and oriley and the both said its good it pass the test so if it was good why it didn't start when i did the jump start with a screwdriver what else could it be ?
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
zmcneely13
Sep 26, 2015 02:26 PM
