removing stuck caliper bolts
So I did pads/rotors for 3 of 4 wheels so far. One rear wheel was easy, 15 minutes.
The other two took HOURS, all because of the caliper mounting bracket bolts.
I broke one in the back, and the one in the front I never could get out so I had to get a whole new caliper/braket.
So I need thoughts on the last one...
I tested it tonight, tried a wrench and a socket.
Banged it with my hand, pushed...
Used some PB spray (3-4 applications) and some rust treatment and kept trying.
Tapped the bolts with a hammer on the head.
Still not budging.
Tomorrow I will probably give my air gun a try, but I just get nervous about the bolt breaking.
I have not tried heat, though I do have a torch. Heat did not work on the other bolts though.
I read on another site some people heat the bolt and apply wax (candle) as a lube...?
Any other thoughts?
What are these mechanics doing that I am not?
Still not budging.
Any other thoughts?
Heat is your best friend, especially if you can get the frozen part off. Last brake job / overhaul, I had to put a torch on one of my caliper pins for about ten solid minutes, it finally popped out like a champagne cork. Good thing I wasn't staring at it at the time
Just some advice
Hey I seldom post on this forum... But, if you do get this bolt off, replace it afterwords. Don't be cheap and re-use a bolt that has been over-torqued and distorted. Go to the dealer or good auto parts store for a replacement.
Also, don't be afraid to cut off the bolt and use the extractor to get it out.
The Frye
Sep 2, 2021 11:03 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
