jdm tranny install now hesitation during start
just replaced with jdm 5spd, no codes. remote start is having trouble starting the car, when it is about to start and stops cranking and shuts down, when in the car using the key it hesitates for a moment before finally cranking one more time to start, any help would be great, thank you.
Never heard of remote start on a manual, probably because you're supposed to park them in 1 or R and you have to push the clutch in on any modern car with a manual transmission to start it. My guess is your problem has something to do with that.
no its very possible u just have ot leave it in neutral..and u can just keep the ebrake up to keep the car still....TINK ABOUTT IIIIIT
Most have a sequence you have to use to set the car for auto start. Auto start the car with the key in the ignition, trans in neutral and e-brake set. Remove keys and exit vehicle, lock doors and shut off car with fob.
If there's any electrical draw (dome or door lights) prior to the remote start being triggered the car will not auto start in case it's not in neutral anymore.
At least that's the way the DEI I installed on a Ford F-550 diesel worked.
This sounds more like a ground or power issue rather than anything affected by the auto start that I'm assuming was installed prior to the swap for the replacement 5-speed.
I have a remote start on my 5spd... You dont leave the car in 1st or R unless you're somewhere with a slope but regardless thats what the hand brake is for unless your ebrake cable is snapped or something you shouldn't have to do that.
yea jdm yo! you dont know bout that? i got it off some dude on ebay told me it was imported from japan hence jdm, took his word for it, anyway. i figured its probably just a bad ground somewhere in the starting system, when the motor is about to start the starter stops and the remote start thinks it started so it wont try and restart, all i did was bypass that clutch switch. but im pretty sure its a bad ground that needs to be replaced or upgraded with a couple of ground wires from the bell housing to the ground and from the starter housing mounting bolts to the bodies ground point near the iacv.
Rage Maximus
Sep 3, 2015 12:26 PM
conansriver
Sep 3, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
