PIAA xtreme white headlights and relay system
Hello Group members,
I got a pair of PIAA 130/110 input headlights which give an output of
200/150W. Since this is high wattage and I dont want to burn out my car's harness, so I also got a Bosch relay system which can support a max of 600W.
The relay system has 2 female socket connectors to connect to the headlight bulb and each connector has a ground wire. It also has one male socket connector to connect to any one car's original headlight socket.
There are 2 wires which go to the 2 fuses of this relay system. The place where I am confused is the instruction manual says that I should connect the main wire to the positive terminal of the battery but there are 2 wires instead of one. Do I need to connect both the wires to the positive terminal? Where does the relay systems get the negative from battery.
I would appreciate an early response.
Thanks.
2K SE A/T
Sherwood Green in California
Thanks.
2K SE A/T
