Need some assistance please
Ok, I was changing out my corner lamp bulb (the one next to the headlight). I had the switch turned on & I was just doing a routine inspection of the socket & I thought I seen something laying inside. So stupid me I grab my pick tool & reach into the socket to get it out & for some reason I had a brain fart & accidentally touch the two terminals at the same time with the tool.
To make a long story short I ended up shorting out the circuit & my running lights are now out / not working. I figured no big deal I'm positive I just blew the fuse. Well I open the fuse panel inside the car & there isn't a spot for "Running Lights" If one of you guy's can point me in the right direction where to locate the fuse for my running lights I would greatly appreciate it.
I felt like a big enough clown by sticking a stupid metal object into the socket & now it's even worse cause I can't locate the damn fuse???
PS, I have also checked the fuse boxes under the hood & no luck. Except for one relay on the passenger side of the car that was looking alittle suspicious???
OH! It should be a 7.5 fuse, I don't remember the name but I blew it out and replaced it. If it helps you should look at the name and find one that relates to when you turn your light stalk up one.
rbaker100
Aug 28, 2015 08:11 PM
Keith Manning
Aug 2, 2001 07:27 AM
Justin Tulli
Jun 23, 2001 09:40 PM
