where to buy/part number trans seal
Does anyone know the part # for the drives side trans seal on a 95 5spd non lsd transmission? Mine is leaking and i need to get one. Autozone doesnt have a part listing for it either.
Thank you
Thank you
Assuming you mean the axle seal, it's 38342-03E00, $7.52 @ Courtesy.
Autozone has it, Timken PN 710118.
Thank you agian.
Check for play in the axle before you waste your money on that seal. Usually when they start to leak, it's a pretty good indication that your diff. bearings are worn.
A very common issue with the 5MT trannys. Replacing the seal usually doesn't fix the leak.
I didnt think the seals were the same from manual to automatic? why wouldnt parts places state that?
thanks for all the help
already checked. thank you
all the same thing i guess, trying to seal the trans up from leaking out the lubricant. but i think most of the Canadian cars are lsd. mine is not for sure
should be the same, but for mine (99 5MT) its oil seal part number 18000 (from canada anyways) and the diameter is 3.558 inches
Originally Posted by Timken's Catalog
Originally Posted by Rock Auto
Originally Posted by Advance Auto Parts
Thank you so much, im going to Advanced auto tomorrow and ordering the part part. I do NOT have the LSD
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
