windows, auto up and down
Could be done I'm sure. I'd say it could be done pretty easy with a relay and a 555 timer circut. You'd have to build a small circut board and wire it up, but yes, it could be done.
http://forums.maxima.org/4th-generat...-possible.html
http://forums.maxima.org/4th-generat...n-windows.html
Has anyone done anything similar to what's in those threads?
In for the results/solution. I miss those features from my 5th gen.
The DEI 530T does the job nicely. I have one in both my 4th gens, and have no issues. I can operate the two front windows from remote, and I also have the "one-touch" open and close.
One of those modules will control two windows in both directions. If you want to control all 4 doors, then you'll need two modules. I only did the fronts. Make sure whoever does the install KNOWS what their doing. This requires the installer to go into each door to make connections right at the window motor. Also, don't use anything thinner than 16guage wire, or else the windows will move slow.
I've installed many of these modules, and have never had an issue with them.
??If not do you mind doing a write up? or is similar to this RSX...
http://forums.clubrsx.com/showthread.php?t=177722
REDinLV
Aug 15, 2024 12:30 AM
