Are Unorthodox pulleys worth it????
Old Dec 2, 2001 | 12:12 PM
maddmaxx's Avatar
Aren't they a big hassle for such little gain????If not prove it.
Old Dec 2, 2001 | 12:34 PM
Cisco's Avatar
Re: Are Unorthodox pulleys worth it????
Not sure bout the pully, but I have an HKS exhaust, Y-pipe and intake and they aint doing jack $hit for me. I'm still venting, sorry!
GC
Old Dec 2, 2001 | 12:39 PM
maddmaxx's Avatar
Re: Re: Are Unorthodox pulleys worth it????
GC
Sorry to here about your xpensive non horsepower gains,how much did you spend????
Old Dec 2, 2001 | 12:45 PM
Cisco's Avatar
Re: Re: Re: Are Unorthodox pulleys worth it????
Spend on what? There is definetly a gain, but not what i expected.
BTW: I am selling off my HKS exhaust to anyone interested. here is the Link:
http://forums.maxima.org/showthread.php?threadid=82111
GC
Old Dec 2, 2001 | 02:35 PM
2kseman's Avatar
Re:Re: Re: Are Unorthodox pulleys worth it????
GC
dude, are you venting before the dynoe results or after the dynoe results....it's o.k. to vent, it's just best to know why you're venting
Old Dec 2, 2001 | 05:08 PM
Cisco's Avatar
Re: Re:Re: Re: Are Unorthodox pulleys worth it????
Venting cuz my car is slow as $hiet! Ran a 16.1 at 85 mph at the track. You may say its the driver, but I had 3 other drivers run my car and to net the same result.
GC
Old Dec 2, 2001 | 05:12 PM
sleepermax's Avatar
Re: Re: Re:Re: Re: Are Unorthodox pulleys worth it????
GC
Something is definitely wrong with you car - you need to get it diagnosed. It could be anything.....
The pulley was one of my first mods and I liked it. It's nothing earth shattering but it does help low end acceleration and I think it also helps when you punch it at highway speeds.
Old Dec 2, 2001 | 06:18 PM
UMD_MaxSE's Avatar
Got Bent?
The UDP is not a bad mod.... it is not earth shattering in terms of gains, but it is noticeable and a nice add-on if you already have intake of some sort and a y-pipe.....
Old Dec 3, 2001 | 05:55 AM
SC2K1's Avatar
Don't expect to get huge gains from the UDP. You will notice a litte bit of low end power but nothing huge.
Old Dec 3, 2001 | 09:21 AM
ReprEsenTin NY's Avatar
Cisco, did you try resetting your CPU, I know that helped a lot for me, after I did that. ..
RPNY
Old Dec 3, 2001 | 09:27 AM
Cisco's Avatar
Why should I have to reset the ECU? Can someone please explain?
RepresentinNYC- Why did u have to reset the ECU?
RPNY
Old Dec 3, 2001 | 12:10 PM
SC2K1's Avatar
I don't think you will need to reset the ECU if you've had the mods on for awhile. The ECU should learn everything as time progresses but it never hurts to do it.
Old Dec 3, 2001 | 12:20 PM
Cisco's Avatar
I did not have to reset the ECu for the Intake and Y-pipe. I doubt i'll need to do the same for the muffler.
GC
Old Dec 3, 2001 | 01:10 PM
irvine78's Avatar
i don't have any complaints about the UDP..so far, it's been ok...
Old Dec 3, 2001 | 02:06 PM
BriGuyMax's Avatar
I really like the UDP....gained 2mph in 1/4 trap with it. ET was off b/c of launching technique.
resetting your ecu will do nothing for your 1/4 mile time. the WOT fuel map is already hardwired into your ecu and you can't change it. Your ecu doesn't "learn" mods for better full throttle acceleration, it learns to be more fuel efficient in part throttle situations becuase of less restriction. If you are running 16s in a modded max...even an auto....then something is DEFINITELY wrong with your car. you should be low 15s now....
Old Dec 3, 2001 | 03:45 PM
Cisco's Avatar
What are the chances of having a "slow" car from the factory?
GC
Old Dec 3, 2001 | 03:57 PM
2001SE's Avatar
GC
lemon but i dought it
Could it be bad coils?
Old Dec 3, 2001 | 04:36 PM
hawkdog's Avatar
cisco
what altitude are you at?? That makes a huge difference.
Old Dec 3, 2001 | 04:44 PM
Cisco's Avatar
Re: cisco
Not sure of the altitude, but I was at a track on eastern Long Island.
GC
Old Dec 3, 2001 | 04:51 PM
hawkdog's Avatar
ok it's not elevation...
I was thinking that cause I ran a 16.1 too, but that was at 6000 ft. above sea level. That translates about to a 15.1 at sea level.
Old Dec 3, 2001 | 04:56 PM
Cisco's Avatar
Re: ok it's not elevation...
I'm hoping to race a stock Maxima and see how I do. I'll be racing RBA and a few other similarly modded max's and see how I make out.
GC
Forge277
Jun 13, 2016 09:26 PM
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
homewrecker
Sep 24, 2015 07:01 PM
