'96 Maxima Oil Transmission
OK
Depending on whether you have an auto or 5 speed the fluid will be different.. But here is the drain and fill procedure for both.. Jack up the car.. Put a jack stand under it.. Ok.. The tranny is on the left side of the car (drivers side if USA)
5-speed
If you look around the tranny you will see a hole that is square about 1/2 way up.. and one below it as well.. Put a the socket wrench in the hole (on top) w/out a socket on it.. and open the upper plug.. If you get it open then open the lower plug and let the fluid out.. when all is drained plug the bottom hole again.. Then keep adding to the top hole till fluid leaks out.. Put the top plug in.. You are done..
Auto..
Remove the bolt from the tranny oil pan.. Let all fluid drain and reinstall bolt.. Open the hood of the car and remove the tranny dip stick.. Take a funnel and add quarts of ATF until you see it on the middle of the mark.. Install stick and put car back on ground.. DRIVE until you get the car to proper operating temp.. Recheck level WHILE CAR IS RUNNING!!! bring to top of the line.. You are done..
5-speed
Auto..
It is not too bad once your started. The worst part on a 5 speed is finding the drain plug. Once you find the drain and refill plug your golden.
Also use this to help you out some. Directions from Maxima Driver
Also I would recomend if your gonna do it to use Redline Tranny Fluid.
SuDZ
SuDZ
Re: OK
I was just wondering how effective this method is to getting cleaner oil to the transmission. I know that supposedly this doesn't get all the oil out unless you do a full flush.
5-speed
Auto..
5-speed
Auto..
Re: Re: OK
Originally posted by AzynRomeo
I have an automatic transmission. Which Redline ATF would I buy? or should I get it from the Nissan dealer?
I have a simmilar question to the person asking about a full flush. I read a manual somewhere and a mechanic told me that a full flush needs to be done. The procedure with removing only the transmission plug will only take out 4 to 5 quarts rather than the 10 to 12... I don't know what the procedure would be to perform a full flush. If someone's reading this and knows the procedures, would you mind posting them?
Answers to these questions and concerns can be found here:
http://forums.maxima.org/showthread....threadid=59048
http://forums.maxima.org/showthread....threadid=45742
Re: Re: Re: OK
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
