Update on Pingking with Coil Packs
Old Dec 5, 2001 | 05:23 AM
neil's Avatar
5 weeks ago took car in, dealer has been good to me, they found TSB 01-059 regarding the coil packs for cars that ping intermittenly. coils came in yesterday, they have a diffrent color code from the stock ones. took 0.45 hrs to install, car is running great, not sluggish anymore and pinging/knocking went away!!!!
neil
Old Dec 5, 2001 | 05:28 AM
UMD_MaxSE's Avatar
Got Bent?
how noticeable was the pinging on yours? Also, did it happen at a specific rpm range?
Old Dec 5, 2001 | 05:32 AM
neil's Avatar
mine was very noticeable and the timing would retard and the car looses a bit of power. after getting out fo first gear and into 2nd gear and you step on the gas it would ping 1/10 times or so. mostly in 2nd gear, or heavy acceleration to get on the highway.
never threw a code, drove the car 3 times with dealer and was able to make it ping once. tech is very good and easy to work with.
neil
Old Dec 5, 2001 | 06:32 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hmmmm..... I wonder if I should change my coils.
Old Dec 5, 2001 | 06:42 AM
UMD_MaxSE's Avatar
Got Bent?
how much is a set of new coil packs?
Old Dec 5, 2001 | 06:45 AM
neil's Avatar
somewhere i read here it was like 80 bucks each ....hmmmm times 6 ..woooooo .......
Old Dec 5, 2001 | 07:22 AM
Y2KevSE's Avatar
I think $60 each or cheaper... spoke to Dave about it but don't remember the exact price.
Old Dec 5, 2001 | 07:42 AM
UMD_MaxSE's Avatar
Got Bent?
hmmm... thats not so bad... making sure your coils are good is more important for you since you are boosted... pinging with boost is very bad
Old Dec 5, 2001 | 07:47 AM
Y2KevSE's Avatar
But I not pinging. Plugs seem to look fine.
Ping + boost = *BOOM*
Old Dec 5, 2001 | 08:06 AM
UMD_MaxSE's Avatar
Got Bent?
if you are pinging, what do your plugs look like? Burnt look?
Old Dec 5, 2001 | 08:11 AM
Y2KevSE's Avatar
White tipped = lean
Black crud = rich
Old Dec 5, 2001 | 08:12 AM
UMD_MaxSE's Avatar
Got Bent?
White tipped = lean
Black crud = rich
i should check mine just for fun
Old Dec 5, 2001 | 08:14 AM
Y2KevSE's Avatar
But then you'll have to put them back in.
Use anti-seize, but don't get it on your hand because you'll get slippery fingers.
Old Dec 5, 2001 | 08:28 AM
UMD_MaxSE's Avatar
Got Bent?
maybe this weekend if the weather is good....
Old Dec 5, 2001 | 08:33 AM
Y2KevSE's Avatar
Don't let the slippery fingers wander far. You might be in for a surprise.
Old Dec 5, 2001 | 08:50 AM
UMD_MaxSE's Avatar
Got Bent?
Old Dec 5, 2001 | 08:59 AM
Y2KevSE's Avatar
Matt can tell you what happens when your fingers start to wander.
<~~~ Him
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
zmcneely13
Sep 26, 2015 02:26 PM
