i got a question about the intake manifold
Okay i have been having problem's with the check engine it keeps throwin an egr code .... well i took it to the mechanie and i bought the new egr and when he was gonna replace it he said it wouldn't work cause my car didn't have the egr lines well years ago i replaced the motor and i think i have a 99 motor in it so now i have to get a new manifold anybody got any idea where i can get that line... i think am missin the line the real small one i think its a 10mm
Look it up here : http://nissan4u.com/parts/maxima/
wow, awesome thread... why not try searching first? first off; if you swapped an engine from a 99 did you also swap the ECU or are you still running your older ECU? cause quite honestly had you searched you'd know you dont even need your egr; and that you can simply block it off and let the sensor dangle...
/thread
/thread
i dont kno if this helps. but wen u get ur system. and ur po400 egr code dont go away try this
http://forums.maxima.org/4th-generat...ing-p0400.html
lux97Max
Sep 4, 2015 05:42 PM
