Rotor doesn't fit caliper odd problem
Old Feb 25, 2010 | 05:15 AM
wirelessdude04's Avatar
So i got EBC slotted/drilled rotors for my front since my rotor's were done as they were. Go to install them yesterday passenger side went on fine. BUt the driver side the caliper isn't fitting the rotor. I pushed the piston all the way back, measured the size of the rotor its the size diameter, but its a just a tad thicker and im sure cause its brand new.Like the brake pad closer to the outside is stopping the rotor from going on. So whatever i mangle it on, meaning hammer the caliper onto the rotor. Drove the car and smelled my brakes and smoke coming from the driver side rotor. So i figured it wasnt safe and just put back on my old rotor.
My question is the driver side rotor didnt align up with the caliper without forcing it. But it did bolt up to the hub but i had to struggle alot for it. Could it be a a bad rotor? Seized cailper, or just leave it the way i had it first and just let the rotor eat the pad down or i could sand the pad down a bit?
Old Feb 25, 2010 | 06:37 AM
cartman854's Avatar
call the peeps you ordered it from, and tell them to replace that rotor first, and see if that changes it, then youll know for sure what it is/isnt.
Old Feb 25, 2010 | 06:58 AM
Yea thats what i'm thinking of doing. Like it fit's but you have to struggle more then your suppose to and it worries me espeically with it being brakes
Old Feb 25, 2010 | 08:08 AM
Blakfreestyle's Avatar
Hey you said you measured the rotor that wouldn't fit... Is it the same thickness and diameter as the passenger side which did fit? If your caliper piston is easy to push in then I would doubt that it is seized. Nothing dangerous about brand new brakes that smoke after a fresh install.
As long as the smoking goes away after a few miles. Let us know what happens.
Old Feb 25, 2010 | 08:23 AM
boya-maxima95's Avatar
im new here but where did u buy the rotor im tring 2 get my 95 right 4 the tracks
Old Feb 25, 2010 | 09:33 AM
I measured it with the driver side rotor I took off. Didnt measure it with the passenger side. Yea i doubt the piston is seized. I'm gonna try it again this weekend. I did last night sorta in a rush and it was cold out. PLus i still gotta add anti-squel to my pads and all
Old Feb 25, 2010 | 11:38 AM
Nealoc187's Avatar
SLOW
Well you measured it, how much thicker is it? they probably just sent you the wrong rotor. there are plenty of nissan rotors that are the same diameter but thicker than 4th gen rotors (which are 22mm).
4th gen = 22mm thick
5th gen = 24mm thick (if my memory is correct)
300zx non turbo certain years = 26mm
J30/Q45 = 28mm
300zx turbo and certain year non turbos = 30mm
All of these rotors have the same diameter as a 4th gen rotor.
Old Feb 25, 2010 | 01:27 PM
J30/Q45 = 28mm
Im pretty sure they did send me a wrong one. Cause the passenger side went on fine. Like butter. Im assuming its probably a 5th gen rotor when i bought them the description said 99-01 rotors emailed the seller he said they would fit fine on a 98.. Could that be it? could i have been dooped lol?
Old Feb 26, 2010 | 09:26 AM
maxx0831's Avatar
i had a similar problem when i had order brembo blanks, come to find out the next day when I warped the new rotor. It was the sliding pins on the driver side. One of them was stuck..
Old Feb 28, 2010 | 03:33 PM
So basically the rotors sent to me were the wrong offset of some sort. Had two other people come look at it and they agrred with me... I was sent the wrong rotors. Now the ebay seller is being a a-hole with me. Telling me i got the wrong rotors
Old Feb 28, 2010 | 03:50 PM
cartman854's Avatar
Tell him you will cancle CC payment, unless its to late.
Old Feb 28, 2010 | 03:53 PM
maxfever1987's Avatar
HOLD ON, YOU SAID YOU pushed the piston all the way,make sure caliper is seized up, because it might just be spinning rather than actually going back, that might be causing the struggle you feel
Old Feb 28, 2010 | 05:56 PM
Nealoc187's Avatar
SLOW
You don't have to spin the piston on the front calipers to push it back in.
Old Mar 1, 2010 | 05:09 AM
yea, i cant cancel payment since it was through paypal through my bank. GOnna dispute it with paypal.
The piston has to be pushed back with a c-clamp.
Old Mar 1, 2010 | 07:43 AM
cartman854's Avatar
Paypal Dipute = Lose
Old Mar 1, 2010 | 03:22 PM
why? he sold me a item that he would refuse to return and or fix
Matt93SE
May 24, 2019 02:58 PM
tcb_02_max
Sep 23, 2015 06:18 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
