Sunroof Control Issue 2002 Maxima
When i got into my car today i went to open the sunroof and the regular pull back control wouldn't work, so i checked the other button that cracks open the sunroof and every time i clicked it it opened the sunroof a little more, as the pull back switch would usually do
. I got the sunroof closed and tapped the controls a few times and now they seem to work fine. I just wondered if anyone else had experienced this and if it was a precursor to future problems. Thanks for any help!
Sounds like it needs to be reset, here's the procedure:
Originally Posted by Sublime258
This happens to me almost everytime I disconnect my battery terminal. I found that this will usually fix it: Use the sunroof tilt switch to open it all the way (you will have to push it a bunch of times), and then do the same thing to close it all the way. Once you open it and close it all the way using the switch, then try using the slider switch thing, and it should open. If it doesn't, turn your car off and back on and try again. This works almost everytime for me.
Off topic, but only slightly - Is there window memory by chance? My passneger side window auto-up puts up the window, then rolls it back down several inches (typical 5.5 gen issue) but for whatever reason it refuses to reset no matter what up/down/reset combos I try - if there's a way to totaly reset the windows similar to the roof, I'd be very happy. The reset button inside the driver door worked fine the 1st time I had to reset it, but now its useless.
Only does it with the auto up function, and I have actually taken the door panel off recently to check to make sure nothing is in the way - which there isnt. Seems to slide on its track just fine.
It happens to my 02 every time I disconnect the battery for working on the car. Reset it and I'm good to go (until the next time).
I need to try this tommorow. After I got done upgrading my stereo my sunroof now only works off the tilt switch. I t worked perfectly before so hopefully this resolves my issues. Thank you for the info, hopefully it works!
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
