can someone explain linear and progressive spring rates
like the title says can someone explain it to me. Ive read a lot and just cant seem to figure it out.
to me it seems like the spring rate changes depending on the load it gets? is that right? how does that work if it is?
thanks for the help. i know its a noob question
B
B
1. Normal Springs (Linear rate Springs, Specific Rate Springs)
In a normal spring, space between the coils are equal. Normal (or linear rate) springs are designed to respond with a specific rate when compressed.
Consider we have a 10-coil spring, each coil spaced 2 centimeters apart. Put a load on the spring to compress it 2 centimeters. Because in Normal Springs coils compress at the same rate, this 2 centimeters will be divided into all 10 coils equal, resulting each coil spaced 1,8 cm apart. Put another additional load which is the same as the first one and the coils will become 1,6 cm apart.
2. Progressive Springs (Rising Rate Springs, Progressive Rate Springs, Progressive Wound Springs)
In progressive springs each coil is spaced differently and have a variable spring rate. When free, it is easy to compress progressive springs for first centimeters. As you apply more forces, coil on a progressive spring come closer. After a certain point, coil at the top 1/4 of progressive springs begin to touch each other and finally become inactive or dead, and that makes the spring stiffer. Apply more forces to a progressive spring then it becomes stiffer because as the number of active coils in a spring decreases, the spring rate increases. So, progressive springs may both be sensitive to very small bumps on the road, while giving the stiffness you need during hard braking and turning.
i would also like to add that most springs you'll find for our cars are STEPPED linear. meaning there are two separate linear spring rates wound into the same spring.
i actually have yet to see a spring with a true progressive wind.
^^^ i agree on that. I was reading on the stepped linear and i too think that is what we have or should i say the majority of "progressive" springs available for our cars are
then the spring rates for the linear or progressive mean the same thing? that is the terminology is the same? higher spring rate is stiffer?
are the amount of drop and the spring rate independent of each other?
B
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
